Grip It & Rip It
Will My Car Pass CA Smog
Pelican Brain Trust:
My car failed. It was fairly warm and then sat for 20-30 minutes before the tech ran it on the dyno. Is it fair to say it would pass if hadn't sat before testing. I say this because it passed the 2nd half of the test but not the first check it out: 1993 BMW 325i 130k miles...recent plugs, filters, coils etc... apologies...meant to post in off-topic
82 911SC (sold) Last edited by edgemar; 06-08-2014 at 03:14 PM.. |
HCs and NOx are really high at idle speed, and the HCs are too close to the limit at cruise. HCs are a result of incomplete combustion. What grade fuel are you running? If you're running 91 octane, try running it very low and adding a half tank or more of 87. Run it for 150-200 miles and have it tested again. Lower octane fuel burns more completely, and should drop the HCs significantly.
The Cap'n |
Checked out
how many miles on the cat?
Grip It & Rip It
Yes was running 91 and there is 130K on the cat...original to car.
82 911SC (sold) |
Under the radar
You might try the BMW forum, there may be some experts there who may be of more help.
