Best way to repair fuel tank leak
There I was sandblasting a bit of rusty exposed fuel tank, where the seal had been scraped off in a previous era.
When fuel started piddling out. I now have a hole about the size of a pin head. What is the best way to repair it? Thanks Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
Caveman Hammer Mechanic
Buy a good used one. With a very few exceptions, it's cheaper and easier. I know from personal experience.
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Yes as click click said a new one. Tip of the iceberg stuff. Lots of pin head sized holes just waiting to bust out
Hi Bill. And where exactly do you think I might find one guys (looking at you Bill - bit scarce down under).
Alan
One of those guys who part out cars on Trademe?
Had a go at the only one listed F/S. But it had to be collected. That meant a 600+Km, 2 day round trip.
I have just persuaded him to ship it. But he is in Oz at moment. Would still like some info on best way to repair tank if possible. The one I've purchased is same age as the one that just leaked, so the same issue is likely to surface sooner or later. Regards Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) Last edited by Alan L; 06-09-2014 at 02:43 AM.. |
1. In the vintage motorcycle realm rusty tanks are commonplace; I believe the go-to solution in that market is called Kreem. Never used it, just hear about it a million times.
2. I've had long-term success repairing external trauma to metal tanks with epoxy.
'90C4 |
Thanks Porterdog - will try and follow that lead up.
Clickclickboom, if I lived in the US and could buy a new tank for $400 it would be a no-brainer. But by the time it gets shipped to NZ you could probably multiply that 3X - based on previous experience of all the bits I've shipped in. Regards Alan
You can't use the tank sealers on the 1973.5 and later gas tanks, inluding the later Motronic. It will clog internal lines and eventualy peel off the internal whirl pot and block fuel flow. Finding a good used or new replacement tank is the only way.
CIS Gas Tank
Ed 1973.5 T |
If the rust has started from the outside (salt etc) rather than inside.
Tank out, paint strip the bottom, coat any rust with phosphoric acid (eats rust at 10x the rate of steel), leave overnight. Wire brush the now soft rust residue, look for holes or depressions that will turn into a hole. Wash out tank with water, run water through it for a few hours. Connect up car tail pipe with hose and run carbon monoxide through the tank when doing the next step. Using conventional brazing rod, fill all holes etc. Go to Wurth store, get various rattle cans of primer, thick underside sealant etc, they have a wide range and you can get a good match on the original with a bit of experimenting. The bit below is more for viewers than the original poster as I can see this thread going pear shaped...... If you are of a timid dispensation and the throught of welding on a gas tank is a bit scary then don't do it. If on the other hand you have a peek down the front of your undershorts and you can find a set of stones, crack on!!!! |
Nice link Ed. Thanks.
Still want to find a decent repair option if possible. My replacement tank of same era is bound to run into same issues. regards Alan
Thanks Texel - that is what I was after - our posts crossed. Wondered if brazing was a useful option. I have all the gear. Your flushing method looks great. Thanks.
Alan
I used soft solder on mine twice, lasted about four years from when it first leaked but you have to accept that it is likely to carry on rusting inside and will clog up the fuel filter eventually. I cut open my fuel filter after four years and the rust deposits made me realise it was time to change.
Ian |
Wer bremst verliert
the easy way is with Kreem inside and JB Weld outside. Beware though, its never just one pinhole...
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Don't use tank Kreem - that stuff is horrible. I used it on a motorcycle tank once - ruined the tank. I did use JB Weld on my Porsche tank a few years ago - it's still holding up fine but I just bought a good used tank to replace it.
Chris '75 911s 3.2 - Ice Green Metallic ‘87 951, '05 987 S '21 Jeep Gladiator ‘18 Tesla ModelX 100D, ‘20 Model 3 |
Under the radar
I repaired two old VW Beetle tanks with permanent success. HOWEVER, the rust was confined to a small area at the bottom near the fuel line. There was not any rust other than at the very bottom BELOW the fuel line where moisture would accumulate.
I made a patch out of COPPER sheet and SOLDERED it over the area. I would only attempt this sort of repair if the rust is confined to a small area.
Hey guys, just pulled tank and had a good look inside. It is mint inside. Not a speck. All external.
So... JB weld, or braze? I suppose if I go JB first and it doesn't work, I can always braze? I have big stones - I track a 930. What else do you need? :-) Thanks Alan
Banned
Hi Alan - I roadraced motorcycles for 10 years - many crashes and gouged tanks throughout the paddock - JB Weld worked perfectly for small repairs time and again.
Does it fix broken bones too? :-) Regards Alan
