930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
914-6 valve adjustment?
Does any one have a link to this? do I lower the motor to get lower valve cover off?
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 06-09-2014, 03:33 PM
If you have unmodified 911 Turbo valve covers, yes, you have to lower the motor to remove them. If you have the stock type covers, you don't. (The mod involves machining off parts of the ribs on the outside of the turbo valve covers to allow them to clear the obstacles.)
The Cap'n
Old 06-09-2014, 03:42 PM
h20cooled7's Avatar
Capn, can i get away with just dropping the rear mounts by the trans enuff to sneak by?
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 06-09-2014, 03:53 PM
To be truthful, I've never had to do this, because I use 911SC lower covers which clear with no problem. I'm sure someone will chime in pretty soon.
The Cap'n
Old 06-09-2014, 04:00 PM
Oh wow. I have a stock 911T motor in mine. I'd hate to have to lower the motor for a valve adjustment!!!
Old 06-09-2014, 04:47 PM
bcheney's Avatar
914/6: Turbo Valve cover mod
Here are pics of the mod that is necessary when using Turbo Valve covers on a 914/6 conversion.
08 Cayenne V6
89 911 Targa Carrera 3.2
75 914-6 Conversion
Old 06-09-2014, 06:04 PM
Makes that "upgrade" less of an upgrade, huh? That's why I use SC lower valve covers. Sturdy, rarely warp under the kind of heat a 2.0-2.4 makes, and they're a drop-in. Oh, and cheaper, too.
The Cap'n
Old 06-10-2014, 01:49 PM
not one of my favorite jobs. fan belts are fun too, and alternator swaps.
206 637 4071
Old 06-10-2014, 02:25 PM
I thought setting the timing would be. With the original Marelli. I sucked a mirror right out of the frame once and was vacuuming glass out of the engine for years afterward.
Old 06-10-2014, 02:27 PM
Fan belts? Yes. Alternators? Piece o'cake for me ............. I always let my partner do 'em.
The Cap'n
Old 06-10-2014, 02:32 PM
Timing? 2 people and a carefully marked flywheel!
The Cap'n
Old 06-10-2014, 02:33 PM
The Cap'n
But you see this how?
Old 06-10-2014, 02:39 PM
Through the hole in the top of the bell housing. You just pry the rear tin out a bit and it's right there ............. Actually, with an adjustable timing light, you need a flywheel with only TDC correctly marked. (Remember, the TDC mark on an original 2.0 flywheel won't be right on a later crankshaft. Tricky devils ....................)
The Cap'n
Old 06-10-2014, 02:44 PM
For the valve covers, you can double nut the studs and remove them where the picture shows the machined valve covers. Then you can get them off. Have them machined before putting them back.
Alternators are easy on a 914-6. I can do one without pulling the intake or the engine. There is a great write up on it here : How to replace a 914-6 alternator.
Clay Perrine
74 914 1.8L (Frodrick)
73 914 /6 4.0L 964 motor (Igor)
70 914 /6 Factory Six. (Elwood)
95 BMW 540i (Inga)
Old 06-11-2014, 10:26 AM
or just use bolts on the lower covers.
206 637 4071
Old 06-11-2014, 11:19 AM
The concept of repeatedly removing and replacing steel fasteners in aluminum bothers me. Porsche (and others) used studs for a very good reason. I suppose you could Helicoil the cam towers in the affected locations.
The Cap'n
Old 06-11-2014, 11:23 AM
'73-914guy's Avatar
The best advice I ever got for doing valves in a 914-6 was to pay someone else to do it..
I have to do valves in a few weeks, and plan to just drop the engine to do it.
Old 06-11-2014, 11:43 AM
