-   -   Flapper Boxes. (http://forums.pelicanparts.com/porsche-911-technical-forum/815422-flapper-boxes.html)
NSW911 06-09-2014 05:42 PM
Flapper Boxes.
This is my first post and may I say that during the last two years spent bringing my ’86 3.2 litre Carrera Coupe up to scratch I have been assisted on many occasions by reading through the solutions to problems contained on this site.
One of these problems was the replacement of the flapper boxes. To put it bluntly mine were shot, completely rusted through and useless. To avoid snapping one or more of the six studs holding down these boxes I elected to use a small nut cracker instead of a spanner to remove the badly corroded nuts. I had already removed the engine and gearbox for other work, allowing easier access.
http://forums.pelicanparts.com/uploa...1402360294.jpg
Counter holding the tool is essential as the wedge is driven in. Very satisfying to hear those old nuts pop off!
http://forums.pelicanparts.com/uploa...1402360975.jpg
Old boxes removed and threads cleaned up.
http://forums.pelicanparts.com/uploa...1402361154.jpg
The old versus the new
http://forums.pelicanparts.com/uploa...1402361317.jpg
Nothing like new boxes and hoses!
The nutcracker used was that able to handle nuts of 3/8 to 1/2 inch or 9-12 mm in size.
This method worked very well for me so I pass it on for what it's worth.
Cheers all.
allaircooled 06-09-2014 05:58 PM
Nice job. I have to do this sooner or later. Going to try and save my boxes first. I don't know how bad they are though.
Determined 06-09-2014 06:06 PM
I've got some boxes for sale that I just posted, I restored them.
allaircooled 06-09-2014 06:22 PM
I saw your ad. They look good!
steely 06-09-2014 06:31 PM
Nice Job - you're good for a long time.
WELCOME by the way - please post a pic of your baby.
Shaun @ Tru6 06-09-2014 06:53 PM
THanks for posting, very timely. I was going to torch these off with oxy-mapp.
http://forums.pelicanparts.com/uploa...1402368810.jpg
allaircooled 06-09-2014 07:01 PM
Yeah I like the nut splitter idea. I wonder if that would work on exhaust nuts.
dondarnell 06-09-2014 07:24 PM
That's a clever application that tool.
NSW911 06-09-2014 07:33 PM
http://forums.pelicanparts.com/uploa...1402370921.jpg
Thanks for the welcome Dan.
After two years of work followed by a full respray in original colour I now have very little left to do, except enjoy driving the beast!
steely 06-09-2014 07:56 PM
Drive it man - she looks great with the tail too.
I need paint someday.
frankc 06-09-2014 09:02 PM
I'm curious, did you old boxes have a rubber cap at the end of the cable to keep out dirt and moisture? I just re-furbished mine and would like to replace the cap but I don't see it in the parts diagram. See photo here:
http://forums.pelicanparts.com/8108464-post157.html
frankc 06-09-2014 09:12 PM
Also, in your third photo there is an extension piece coming out of the old box on top. This piece is shown in the parts diagram, but was not present on my car when I removed the boxes. Does anyone know what function it serves? Does it simply prevent the hose from dropping down on something?
NSW911 06-09-2014 09:21 PM
frankc------I have also searched for the rubber cap you mentioned but have not seen it listed in any parts diagrams.
The extension piece exiting one of the boxes is the temperature probe for the automatic heating system. From memory the auto heat system was incorporated in cars manufactured from 1984 onwards.
81SC 06-10-2014 12:09 AM
Gentlemen,
Pelican has the rubber grommet for the heater cable guide tube. They have 26 in stock.Pelican Parts - Product Information: 914-504-319-00-M100 Product Information: 914-504-319-00-M100
NSW911 06-10-2014 02:55 AM
Flapper Boxes
81SC------thanks for that. My search was obviously not thorough enough!
JJ 911SC 06-10-2014 03:34 AM
I think they are beyond my "10 Steps Program... http://forums.pelicanparts.com/porsche-911-technical-forum/589980-cleaning-flapper-boxes.html
BlueWing 06-10-2014 05:37 AM
I used a Dremal tool with a flexible shaft and good fiber re-enforced cut off wheel. Cut a slot on the side of the nut, once the slot was cut a small chisel hit in the ccw direction would break it loose. When loose I was able to use a socket to remove.http://forums.pelicanparts.com/uploa...1402407356.jpg
http://forums.pelicanparts.com/uploa...1402407384.jpg
Terry
kach22i 06-10-2014 07:15 AM
Where did you get that tool from?
This one below looks different, any idea which style is best?
Craftsman Nut Cracker
Sears.com
http://forums.pelicanparts.com/uploa...1402413277.jpg
Description Item # 00904772000P Model # 4772
This small and compact tool will split nuts from 5/16 to 7/8 in. across flats. A hardened steel cutter, this is a hand tool only. Not to be used with power tools.
The smaller nuts like on the bumperettes and other bumper rubber have snapped on me. Smaller than 3/8" would be nice too, something down to 1/4" or below 8mm.
red911s 06-10-2014 07:59 AM
Where did you purchase the "orange" hoses? Thanks,
Bob
wrxnofx 06-10-2014 09:20 AM
Bob
They are available on Pelican here.
wrxnofx 06-10-2014 09:32 AM
Originally Posted by 81SC (Post 8108568)
Gentlemen,
Not sure how they're different, but there is a different P/N for the '87-'89 Carreras:
P/N 999-702-154-40-OEM
frankc 06-10-2014 10:17 AM
I noticed the end of the guide tube was flared in the picture of the new boxes. Perhaps this 999 part number is for the flared style?
I just ordered two of the 914 part numbers since I have the non-flared style and that number is what is shown in the parts diagram for my '77.
red911s 06-10-2014 12:38 PM
wrxnofx -
Thanks for the Pelican "here" link -- my question is that when I pull up that Pelican link, there are no pictures of the Genuine Porsche Brand parts. Also, there are two parts listed, so I did not know if the heater hoses are "orange" on the outside, just like the original ones on my car, or are they orange on the inside and whitish on the outside?
Bob
wrxnofx 06-10-2014 07:47 PM
Originally Posted by red911s (Post 8109465)
wrxnofx -
Bob
I see what you mean, Bob. I can't really tell, either, since the Porsche OEM ones don't have a picture.
frankc 06-10-2014 08:34 PM
The non Genuine Porsche part has some type of white fabric over it. It is difficult to see in the catalog photo, but see picture 5 in my following post for a better view:
http://forums.pelicanparts.com/8106677-post152.html
NSW911 06-10-2014 09:05 PM
Flapper Boxes
kach221,--------There is no reason why the Craftsman tool pictured in your post should not work as well as the one I used except for one thing,------it may be too hefty to fit into the space between the outside of the nuts and the flapper box body.
The dimensions of the splitter I used are as follows:-
Length (excluding wedge screw end)-------2.4"
Circular head outside diameter--------------0.87"
Circular head inside diameter----------------0.54"
This was the smallest splitter included in a set of four purchased from "AUTOTOOLS", a company based in Victoria Australia and from memory I could not have done the job if the splitter had been any larger.
Their products can be viewed via their website:-www.autotools.com.au
Best of luck,
Don.
