83 911 Production Cab #10
JJ 911SC's Avatar
Cleaning Flapper Boxes
After posting some photos of cleaning the Flapper Boxes that I got from Peter Seow ($40 delivered from Singapore), Felipe asks me about the cleaning process, so here it is.
I disassemble one at the time so I could have a reference when it came time to reassemble (mirror image to each other);
My basic cleaner is call Facto AT-30 from http:www.swishclean.com/clean-itcenters.htm?ECINFO=//SWISHLOCATIONS (Canada/US/Europe)
Less than $5 a Liter when bought in a pale. Hopefully there is a store close to you.
Check my cleaning thread: http://forums.pelicanparts.com/cleaning-detailing-polishing/550748-best-cleaner-bar-none.html
Step 1: Remove the spring on the other side (not shown) and clean the center piece.
Step 2: Remove the captive clip from the shaft.
Step 3: Carefully removed the plastic bushing (red) by prying it side to side. It may already be cracked or you may crack it or split it all together. I don’t think you can buy them on their own but even if they are cracked or broken (crazy glue should work) they should still work as the fit into a recess.
Step 4: Pull (or pry off) other side as the shaft slide through the flapper. I may require a gentle hammer hit to get it loose.
Step 5: Removed the inside flapper.
Step 6: Clean/paint to you heart content.
Step 7: Reassemble by sliding the bar through the flapper (the cleanest side go toward the inside of the car as shown).
Step 8: Insert the plastic bushing.
Step 9: Secure the retaining clip on the shaft end.
Step 10: Reinstall the spring.
Who Will Live... Will See
Old 02-05-2011, 05:09 PM
faverymi's Avatar
Thank you JJ
That was sooooo helpful. No more rusty ugly flappers!!!
Old 02-05-2011, 05:30 PM
Band.
That's a great write up!
Old 02-05-2011, 08:16 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Doh! another job! thanks allot there goes my weekend :-(
'85 Carrera Targa
PCA/POC
Old 02-05-2011, 08:27 PM
AutoBahned
RWebb's Avatar
I would get them plated before reinstalling - they will surely rust quickly if they are not at least plated.
These things should be made from Al or stainless...
Old 02-06-2011, 10:59 AM
Packy's Avatar
Spray it with CLEAR rustoleum after and the rust will stay away longer. Obviously don't spray moving parts together.
EDIT: or do what RWebb suggested. Plating is probably more correct, but more expensive. I usually spray all my exposed fasteners too.
(1) '77 Chassis and '79 SC 3.0 project car
(1) '79 911SC 3.0 Widebody SC
(1) '15 Ford F-150 4x4 3.5TT
Toluca Lake, CA
Old 02-07-2011, 11:56 AM
a.k.a. G-man
Geronimo '74's Avatar
Good little project!!
Thanks for posting!
Old 02-07-2011, 11:59 AM
Wine User
warner53's Avatar
Old 02-07-2011, 12:10 PM
