no popping on acceleration with most of the lower studs broken? hard to imagine.
206 637 4071
Old 06-16-2014, 03:18 PM
I bought a 78 SC with 8,484 miles. It was last licensed in 98 or so. Had the popping sound and all 12 exhaust head studs were broken. Engine was removed in less than 4 hours and dissembles that weekend. Hardest part was getting the broken studs out. Use heat and vice grips. Hopefully enough left to grab. No other damage. Put in upgraded tensioner. Once I had all studs out and all gaskets in stock, I spent about 35 hours re assembling, measuring, installing etc. I would remove the transmission with the car. Be sure to use Locktite on the axle shafts to transmission flanges. Ask me how I know.
Ask many questions. Folks on the board are great!
Old 06-16-2014, 03:38 PM
Shaun @ Tru6's Avatar
New schnorr washers and running small rags through each hole, last one with brakekleen on it so the bolt threads don't pick up CV grease works as well.
I think backed out bolts are mostly due to greased threads and worn washers.
Tru6 Restoration & Design
Old 06-16-2014, 04:54 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
The definitive thread, with lots of Grady:
Reconstructing Constant Velocity (CV) Joints
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 06-17-2014, 06:49 AM
Straight shooter
Lapkritis's Avatar
Good luck lespaul. If you hit snags there are plenty of 802 Pelican's who can help - I also just completed a top end job in the spring of last year. Plenty of helpful knowledge among members here eager to share.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 06-17-2014, 07:33 AM
