-   -   89 Carrera engine install questions (http://forums.pelicanparts.com/porsche-911-technical-forum/817266-89-carrera-engine-install-questions.html)
bcheney 06-21-2014 11:51 AM
Ok getting ready to reinstall my rebuilt engine... I started today and first up was reinstallation of the return fuel line that runs up from the cabin firewall into the engine bay into the injection system. There is some kind of vacum line that runs along with it through a couple of carriers. See pics "circled" in green. It runs from the top of the first pick into the engine bay. From here I am not sure where it went. Pics 2 and 3 are where I'm thinking it went....attaching to another larger diameter line joined by a double male end connector. Is this correct? Can you tell me what this line does...My guess is that it is a vacum line of somekind. http://forums.pelicanparts.com/uploa...1403376637.jpg
http://forums.pelicanparts.com/uploa...1403376659.jpg
http://forums.pelicanparts.com/uploa...1403376674.jpg
DRACO A5OG 06-21-2014 12:00 PM
As I recall, I think that's is correct, it goes to the carbon filter canister
bcheney 06-21-2014 12:06 PM
Carrera
DRACO...so it makes it way from up front..to engine bay...to the cannister in the right rear fender well?
DRACO A5OG 06-21-2014 12:25 PM
Yes, as I recall, it is the vapor line that goes into the canister.
Let's wait for others to confirm.
kodioneill 06-21-2014 02:55 PM
Draco is correct vapor lines to the charcoal canister.
bcheney 06-21-2014 08:55 PM
Lines
Thanks so much!
