89 Carrera engine install questions
Ok getting ready to reinstall my rebuilt engine... I started today and first up was reinstallation of the return fuel line that runs up from the cabin firewall into the engine bay into the injection system. There is some kind of vacum line that runs along with it through a couple of carriers. See pics "circled" in green. It runs from the top of the first pick into the engine bay. From here I am not sure where it went. Pics 2 and 3 are where I'm thinking it went....attaching to another larger diameter line joined by a double male end connector. Is this correct? Can you tell me what this line does...My guess is that it is a vacum line of somekind.
08 Cayenne V6 89 911 Targa Carrera 3.2 75 914-6 Conversion Last edited by bcheney; 06-21-2014 at 11:55 AM.. |
Member 911 Anonymous
As I recall, I think that's is correct, it goes to the carbon filter canister
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Carrera
DRACO...so it makes it way from up front..to engine bay...to the cannister in the right rear fender well?
08 Cayenne V6 89 911 Targa Carrera 3.2 75 914-6 Conversion Last edited by bcheney; 06-21-2014 at 12:09 PM.. |
Yes, as I recall, it is the vapor line that goes into the canister.
Let's wait for others to confirm.
Draco is correct vapor lines to the charcoal canister.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Lines
Thanks so much!
08 Cayenne V6 89 911 Targa Carrera 3.2 75 914-6 Conversion |
