Speedometer needle issue
I have 912E from 1976. It's a 912 by name, 911 by chassis and many parts and a 914 by engine and some parts, so hard to post the right place.
My speedometer acts wird. When I drive and then hold still, it shows almost 30 mph. And when I accelerate or keep a steady pace, the needle is 'jumping' up and down around the current mph. It's really annoying. As I have been told, the car does not have a cable to trigger the speedometer but an electronic impulse sender instead. What could be wrong and where should i start? Both a new used speedometer as well as the impulse sender is quite expensive, so I will try to locate the error before buying parts. |
Member 911 Anonymous
Most likely a dirty ground or failing sensor at the gear box. But check the cheap stuff first.
Pull the gauge and check, clean and insure a tight fit. if there is an intermediate connection check, clean and insure a tight fit. Check the sensor is clean and no obstructions at the mount.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Thanks.
A ground wire had jumped out and was burried in the wire chaos |
