-   -   Need advice, both drop links broke. What part do I need to fix? (http://forums.pelicanparts.com/porsche-911-technical-forum/817737-need-advice-both-drop-links-broke-what-part-do-i-need-fix.html)
Fubawu 06-24-2014 07:57 AM
HI
Hard story to convey but basically I notced that both my front drop links had cracked at the threaded monoball point. Not sure why, I am guessing too much stress at that point due to it not being properly mounted. Thats another story.
Here is a picture of the product. The part that broke is the small threaded pivot that attaches to the gold bracket on the top of the sway bar. Any suggestions on what to use in it's place or where to get a replacment??
http://forums.pelicanparts.com/uploa...1403625337.jpg
Fubawu 06-24-2014 08:04 AM
here is the broken piece. I am not sure what the part is called :)
http://forums.pelicanparts.com/uploa...1403625840.jpg
The cap'n 06-24-2014 08:11 AM
That part is called a "Heim joint". They're sold all over the place. Gotta have the specs, though. Size, thread size, left or right hand thread, material. You might want to contact the place you bought the kit, or the manufacturer.
The Cap'n
Fubawu 06-24-2014 08:21 AM
thanks cap'n! Smart racing made the product but they are not selling suspenion parts anymore. Also they are somewhat MIA now. I will see if I can find a replacement at a local
shop. Knowing the part name helps!!
tharbert 06-24-2014 08:21 AM
Those are obviously aftermarket. What brand? Patrick Motorsports, Tarett Engineering or Rebel Racing will probably have parts.
The cap'n 06-24-2014 08:24 AM
Google "Heim joint"....... There are a lot of sources there, and you can measure what you have, check the thread size, pitch, and direction to aid in ordering.
The Cap'n
911pcars 06-24-2014 09:20 AM
Selecting rod ends or Heim joints is an area manufacturers can extend their profit margin and/or make their product more competitively priced. Some use inexpensive carbon steel units; the best rod ends are made from high quality, high-strength, heat-treated alloys and other high-end treatment. In addition, there's a wide quality range between them. For example, the cost for a typical 5/16"-3/8" (M8) rod bearing can be $3-$100 each (x 4 for two front drop links).
If Smart Racing were still in operation, they would probably replace the failed rod bearing. Street applications usually don't create as much stress or suffer catastrophic results compared with track use, so plan accordingly. BTW, famed race driver, Jim Clark, crashed and died when his sway bar (or link) failed at speed.
Here are a couple of sources (no affiliation) for rod ends.
NMB /NHBB Rod End Index
Suspension Arms, Bushings and Accessories, Heim Joints from Speedway Motors, America's Oldest Speed Shop
Sherwood
Robey5 06-24-2014 09:25 AM
The Cap'n is on the right path. You're going to want to know the material and thread direction/size of the thread.
The item that broke in your suspension can be replaced by purchasing a "rod end" from the Aurora company (site below)
Rod Ends, Spherical Bearings & Bushings - Aurora Bearing Company
Typically - these parts brake at the threads (the weakest point of the part in tension or compression) - maybe you might want to use a higher strength material - as it looks like the one you have that broke may be experiencing a side load it wasn't expecting.
Cool part though!
wayner 06-24-2014 09:27 AM
I got my smart racing replacement parts at Jerry woods
Jesse16 06-24-2014 10:05 AM
Good Ol McMaster Carr
Has a huge selection. I would assume they're a purchased part. I'd be surprised if anyone made their own. Measure yours up and buy.
Fubawu 06-24-2014 10:21 AM
Just spoke with Jerry at Smart Racing aka Jerry Woods racing. Nice guy and explained to me why the part broke. I did not have it tightend down all the way and it twisted on the swaybar.
This put pressure on the thread until it broke. Makes sense when I look at it. The car was not in use yet so a proper nut and bolt check had not happened. He is providing me with the proper parts.
great service!!
Cheers
John
