How to Remove "Water Stains" from Fuchs Wheels?
I posted this in the Cleaning, Detailing, and Polishing forum, but no one ever seems to visit that one.
Anyway, I am finally at the point of being able to think about detailing aspects of my '87 Coupe that I picked up last summer. Here is a pic of one of my wheels: ![]() I cannot get this "staining" off the silver part of the wheel. I've tried rubbing compound, metal polish, scotch brite pads, and none of it touches it. Is the anodizing etched? Is it ruined, or does someone have a suggestion of how to get these spots off?
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus |
That really looks like damage from a wheel cleaner with the wrong PH. It really looks like your anodizing may be damaged. Take a wheel off and look at it with a magnifying glass. See if the surface has a different texture to the finish.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
You'll have to refinish the wheels to fix that. You might try rubbing in a little Vaseline to make them look better in the meantime.
JR |
Under the radar
I have had some luck with liquid car wax. NOT polish.
Fb = M/S
Did you use a degreaser, like Simple Green? Some degreasers will cause staining. It looks like some was sprayed on and sat for awhile and stained the anodizing.
Won't come out unless you refinish.
1981 911SC, Guards Red/Black Leather 2014 Audi A6 Prestige, Phantom Black Pearl/Black Leather, Black Optics 2017 Tesla Model X Gone but not forgotten: 1969 Datsun 2000, 1973 914 1.7, 1976 912E |
Thanks for quick responses, everyone. You confirmed what I was fearing.
I'll try some liquid wax and see if that makes it look a little more tolerable. Quote:
I agree 100% with javadog.
Really unfortunate to see that. Always a bummer to have to tell clients "sorry I can't do much" The Vaseline is no joke either. The petroleum jelly will will soak in to the anodize and cause it to become slightly less opaque looking. You can also wax the wheels with a synthetic like Meguiar's NXT Tech Wax. You will have to apply often. Similar effect as Vaseline but less messy. Cooper |
Model Citizen
Vaseline, for sure, is where to start.
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
(man/dude)
I would not give up on those wheels and send them to be refinished quite yet.....The finest (white?) 3M scotchbrite pad, used wet, is worth a try. The abrasives in the pad are basically the same or equal hardness to the anodizing and will have some effect. The eventual finish might not be quite a glossy as the original, but even a coat of glaze will help that.
Would be interested to know the result. FYI I tried this using a grey 3M pad on a wheel in worse shape than yours and was pleased with the results but had already stripped the anodizing off the other three wheels so didn't pursue it. I think it's worth a try, at least. If you like I can try it on a spare wheel and post the results later. Last edited by Jonny042; 05-30-2014 at 07:56 AM.. |
Make America Great Again!
+123 Really, try the Vaseline as mentioned above first...cheap and works...
Vendor
Location: 155 Commerce Drive | Fort Washington, PA 19034
ive seen people us WD-40 on those
Hamsa Naser Hamsa@fabspeed.com W: +1 267 742 3006 |
What brand of rubbing compound / metal Polish did you try? My Fuchs wheels looked just like yours. A few months ago, I tried Mother's Mag & Aluminum Polish and Wenol (blue tube). I started with the Mother's and went through several applications and removal, and finished with the Wenol. I was stunned by the transformation. Well worth the effort.
I dismount and mount my own tires. Leaving the tire lube on the wheels can cause the same effect to the anodizing ;(
HB Kramer (4 sneaks and 6 airheads): 79 911SC Coupe (sunroof delete) (2 sneaks and 2 airheads): BMWS: R12GS(a) R90S, and some old British iron as well. |
Anyway, here is the result on one of the wheels. At minimum, it does look way better than it did in the past.
Taking it apart is easy
If that's the same wheel as the one pictured in the first post, it's a remarkable improvement. I'm gonna try it.
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com |
You can clearly see the "staining" is still there, but it's a lot more subtle, and in certain light (outdoors, for example), you can't really see it. Not sure what the metal polish is doing, as it's not technically polishing anything (the rag doesn't turn black so there is no chemical reaction going on with any metal, which makes sense since this is anodizing).
Thanks. Still an improvement.
No worries. I just didn't want to get your hopes up too much, that's all.
