WydRyd's Avatar
Flowed Carrera 3.2 Intake
I was just browsing the RennSport WEB page and came across this section/table:-
Airflow comparisons from 3.2 Carrera Stock vs Flowed Intake Manifolds
Cylinder Stock Airflow cfm Flowed Airflow cfm
#1 277 351
#2 280 349
#3 280 351
#4 295 351
#5 286 349
#6 289 352
(DAMN! Excuse the formatting!)
It seems that there can be substantial gains from having the Intake Manifold flowed properly, especially for a forced induction setup coupled with Pressure Sensing.
Has anybody perfomed such a mod and if so, how much does it typically cost to have the intake manifold flowed?
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 09-25-2002, 06:55 PM
juan ruiz's Avatar
Extrune Hone $600USD, Home made Ported FREE
Old 09-25-2002, 07:08 PM
WydRyd's Avatar
Is that what you did Juan? "Hand-ported" at home?
Were your heads match-ported also?
Merv
'89 911 Turbo Cab
Old 09-25-2002, 07:18 PM
juan ruiz's Avatar
Yes thats what we did Ported the Intake Manifold by hand at the shop and Ported the Heads by hand also, but we ported both the Intake & Exhaust
Old 09-25-2002, 07:24 PM
A Quiet Boom's Avatar
Just a few comments, those numbers would amount to a substantial increase in HP, on a V8 that much flow would be good to well over 650 NA and a lot more with force induction assumming the cam gets up into that lift range long enough. Note: My Mustang heads flow somewhere around 310 or so with about 650hp on tap. What where the specifics of the test? was it done at industry standard 28" water? As far as home porting goes, it's not for the uninformed or faint of heart you can actually make LESS HP with incorrectly ported heads. Do some research on porting race car heads before attempting this. You could just polish them up a bit without doing to much harm, just leave a slightly rough surface on the intake side.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com
1966 912 converted to 3.0 and IROC body SOLD unfortunately
1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity!
Old 09-25-2002, 08:53 PM
WydRyd's Avatar
AQB - I agree, those numbers would equate to some serious HP capability, providing everything else is matched accordingly.
I can't really give you specifics, but here's the URL if you are interested. I will query RennSport about these figures and test setup.
http://www.rennsportsystems.com/~porsche/engines%202.7-3.2.html
If I were to perform such a mod, I wouldn't dare attempt it myself. I'd have the manifold and heads sent away to be matched ported, flowed and polished by a suitably qualified shop.
At a guess, I'd say that you'd also require a larger throttle body to match the increased flow rate?
Merv
'89 911 Turbo Cab
Old 09-25-2002, 09:10 PM
Yep, only as good as the smallest restriction as they say. Throttle-bodys can be sized according to HP level desired. I'll have to dig up a Mustang page to give you an idea. It's something like 1mm per 5hp if I remember right, just rule of thumb though.
Old 09-25-2002, 09:48 PM
Steve W's Avatar
I would think for forced induction setups, flow balancing the intake manifold would not have much of an effect on hp, cuz you already forcing as much air as the motor can take with the turbo. I had my manifolds ExtrudeHoned years ago, I think it cost me $600 buxs, but my car is n/a. The insides of the manifolds sure are smooth as silk. Smoothing out the intakes effectively makes the runners larger at hi flow, because with the stock cast surface, eddie currents are generated along the surface at high flow, which reduce the effective diameter of the runners. Bruce Anderson and Jerry Woods dynoed a 7 hp gain on a 3.2 with the ExtHoned manifolds from something like 4700 up.
Old 09-25-2002, 10:30 PM
Actually flow balancing between cylinders is more critical on boosted engines to keep detonation at bay. Besides porting will make the turbo more efficient on both sides and most likely spool up faster.
Old 09-25-2002, 10:48 PM
beepbeep's Avatar
One question to you 3.2 guys: Are there any spacers between 3.2 intake and heads? Or is it only gasket? Also, what's the diameter of intake on 3.2?
I'm still thinking about smacking one of those on 930 togheter with EFI, don't have money for time being tough.
Thank you for your time,
Old 09-26-2002, 04:42 AM
Irrationally exuberant
ChrisBennet's Avatar
Yes , there is a 10mm (?) plastic spacer between the heads and the intake with gaskets on both sides.
-Chris
Old 09-26-2002, 06:39 AM
