What's this connector for??
What's this 3-wire (brown, gray, black/yellow) connector for?? Located in the engine compartment, passenger side by oil tank, 1987 930. The wiring harness on that side has the the tail lights, AC, oil level sender and this misc connector. I can't seem to find it on the wiring schematic.
Thanks!!!
Bill
1987 Marine Blue 911 Carrera Coupe RIP 01/2011
1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint
Old 06-28-2014, 02:54 PM
steely's Avatar
Decklid light I believe.
In mine there is a small clamp on the inside fwd of the oil tank - he mating connector worked its way up the decklid hinge.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 06-28-2014, 05:19 PM
Synchro Joe's Avatar
Also for a 3rd brake light if you have one. Gray is for engine compartment light, black/yellow is the brake light and brown is the ground connection for the two. On mine the two grounds are connected via a Y-connection into one common wire that runs to the plug.
Horsepower is how fast you hit a wall.Torque is how far you will take the wall with you.
Old 06-29-2014, 01:07 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Connector
Here.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 06-29-2014, 04:00 PM
