Turbo Hooligan
D-Zug 935 K3 Pikes Peak Build
Over the course of the past year we've completely overhauled this 930 and we'd like to share the journey with you. We'll start at what race cars don't need...sound deadening/undercoating and go from there. Since I'm not much of a wordsmith I'll let the pictures do the talking.
Time to remove whats left of the sound deadening that was in the cabin.
Getting there...lots of multitool scrapers and wire wheels were killed in the process.
Once a section was finished it was immediately primed and painted. at the beach things rust quickly, we take a lot of preventative measures to keep the tin worms away.
D-Zug
Old 05-25-2014, 04:27 PM
Turbo Hooligan
Once the inside of the tub was done, we moved on to stripping the frunk of all wiring, hvac, etc.
Once a section was stripped and cleaned we immediately primed and painted just as with the inside.
Then we started on the wheel wells
Otto inspecting our work.
He approved of the weight reduction!
D-Zug
Old 05-25-2014, 04:36 PM
Turbo Hooligan
Rinse lather and repeat for the quarters
can't forget about the engine bay.
D-Zug
Old 05-25-2014, 04:43 PM
Turbo Hooligan
I'm not sure why some of the pictures are transferring upside down. I apologize but I'm not going to make an effort to fix them.
D-Zug
Old 05-25-2014, 04:44 PM
912 Geek
Are you planning to run this year?
Old 05-25-2014, 04:47 PM
Turbo Hooligan
I'll spare you all the rest of the tub stripping and painting pictures, it was done the hard way with scrapers and wire wheels and I'd rather not relive those weeks of my life. Lets move on to fitting new rocker panels
looks like everything lines up
D-Zug
Old 05-25-2014, 04:50 PM
Turbo Hooligan
We forgot to document this better, but heres the skim coat after the passenger side wiper was cut out and welded up.
We had to fabricate all new windows
D-Zug
Old 05-25-2014, 04:57 PM
Turbo Hooligan
911R tail light housings refinished.
D-Zug
Old 05-25-2014, 05:01 PM
Turbo Hooligan
Quarter panels getting blocked for a better appearance.
D-Zug
Old 05-25-2014, 05:07 PM
Turbo Hooligan
Primed and sealed
Full carbon GT2 evo doors were up next
D-Zug
Old 05-25-2014, 05:15 PM
Turbo Hooligan
Starting on the nose
D-Zug
Old 05-25-2014, 05:18 PM
Turbo Hooligan
We have some color on the panels!
D-Zug
Old 05-25-2014, 05:25 PM
Turbo Hooligan
Doors Done!
Showing the carbon skin on the inside!
added some color to the tub
Shaved rain gutters...mmmmmm
D-Zug
Old 05-25-2014, 05:34 PM
Turbo Hooligan
Fabricated headlight covers
Practice starts 4am so we upgraded the old driving lights to our own D-Zug HID's
Turn signals installed...a must for a road legal race car.
D-Zug
Old 05-25-2014, 05:40 PM
Turbo Hooligan
Body panels coming together
Fabricating new wing endplates
D-Zug
Old 05-25-2014, 05:44 PM
Turbo Hooligan
Fabricated gurney flaps for the quarter panels
New windows in place!
D-Zug
Old 05-25-2014, 05:49 PM
Turbo Hooligan
If it walks like a K3 and talks like a K3...
D-Zug
Old 05-25-2014, 06:04 PM
Almost Banned Once
sc_rufctr's Avatar
Cool build... Thanks
- Peter
Old 05-25-2014, 06:17 PM
Turbo Hooligan
admiration phase is over, back to the grindstone.
since the cars po had cut out the front of the tub to route the oil cooler through the hood, we had to fabricate the very front of the tub from sheet steel. which lead to relocating the battery, and reshaping the tub so the air through the front oil cooler exits through the fender vents instead of under the car and adding brake ducts/nose mounts.
D-Zug
Old 05-25-2014, 06:37 PM
Turbo Hooligan
After finishing the tub modifications, we could finish wiring up the brains of the operation. with new wires run for the entire car we ensured that 30 year old electrical gremlins wouldn't catch us off guard.
D-Zug
Old 05-25-2014, 06:41 PM
