-   -   Replacing Marelli Dizzy (http://forums.pelicanparts.com/porsche-911-technical-forum/81876-replacing-marelli-dizzy.html)
wit61 09-25-2002 12:21 PM
Pelican indicates that the bosch replacement for the Marelli dizzy is on backorder with no ETA ! Does anyone know of an alternate source (new or rebuilt) that has one in stock or a list member with one FS ?
TIA
CamB 09-25-2002 03:00 PM
For a man who obviously has a fine taste in cars, I will point you to the search function.
Search for "Marelli" with the username "Fishcop". Or click the link below:
http://forums.pelicanparts.com/search.php?s=&action=showresults&searchid=129140&s ortby=lastpost&sortorder=descending
Basically, you can probably find a 2.7CIS distributor and get it machined (if needed) to fit. Then you get it recurved and you're done.
Should be cheaper than the "new" price.
Fishcop 09-25-2002 03:30 PM
It is cheaper! :D
CamB 09-25-2002 03:34 PM
John
I couldn't figure out if you ever had yours recurved?
Fishcop 09-25-2002 03:51 PM
No I haven't yet. The curves are remarkably similar and I am lazy... The wheels will be off the car for a couple of weeks from next week (for restoration), so I'll probably send the dizzy away at that stage. I've been quoted $125 for full rebuild and re-curve. As it doesn't need a rebuild, the re-curve shouldn't cost me too much.
Still got snow over there? Absolutely starting to cook here again!
CamB 09-25-2002 04:14 PM
Didn't make it down this year, but I hear from someone at work that it has been raining on Ruapehu. NOT good for snow cover.
South Island might still be ok.
wit61 09-26-2002 06:54 AM
Hey CamB,
Thanks, your taste in cars is not too shabby either ;)
