Who does ultrasonic parts cleaning?
Any recommendations for getting engine parts cleaned. Intake manifold, fan, fan housing, cam housings etc. Has anyone used Ultrasonic Cleaning Corp. in Carson, CA?
Harold '79 930/DP935 (sold) '68 VW 3.3 Turbo Crewcab |
Always Be Fixing Cars
Dunno if you're also doing the heads, but if you are... these guys are top shelf and their main business is ultrasonic cleaning. The heads come back better than new, and with UPS, shipping wasn't much over $25 if I recall.
Anchor Atlantic Enterprises LLC - Home
'91 964 C4 - New Daily '73 Alfa GTV - 90% done 50% to go '65 912 - Welding in process |
Just looking to get the above parts cleaned.
Gumba, if that is the place on Main St I've used them a lot for blown Harley motors. It's amazing what they get out after you think you have it clean. They always handed back a sealed back of explosion with all the cleaned and sealed in a bag parts. Always a good experience with those people. Mike.
Mike Trashed Turbolook Cab per Milt, 1965 Pontiac Tempest 1953 Lincoln Capri La Carrera copy(finished soon I hope) 2008 HD Orange Roadglide (The Flying Carrot) 1961 Chevy C10 V-8 shortwide, big back window(project) |
That's them, thanks.
For general parts cleaning, try your local transmission shop. The one down the street lets me fit as much as I can in their parts washer for $20. An example of before and after
You put the entire transmission in the parts cleaner?
No, everything was out of the case. I was in the process of rebuilding it. You can't put anything in the parts cleaner with rubber attached to it.
Ryan |
Or Dry Ice blaster around? |
Be careful with magnesium parts.
the ultrasonic bores small pin holes into the casting. Deep too!
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
Thanks for your input
Mike '89 CARRERA #402 |
Ultrasonic Cleaning and Head Work
Absolutely consider using Bob Hirst and Anchor Atlantic Enterprises LLC. They are fantastic. I have used them several times for machine shop work on air cooled Porsche cylinder heads and cleaning pistons and cylinders.
http://www.precisionheads.com/ They are in Pitman, New Jersey Henry Last edited by Hcarraro; 07-03-2014 at 07:59 PM.. |
