another heater back date question
I have moved to Cali and my 79 SC is in Indiana and I cannot look at it to answer a heater backdate question. Is there a blank off plate on the passenger side fan shroud cover of will i have to cut a hole there to mount the piping
Heater backdate.........
Yes, the passenger side plate is flat and solid. You will either have to modify the stock plate or replace it with one from Pelican Parts. If you have air, I found that making the pipe oval instead of round helped make everything fit better. Good luck!
I had changed out the York for a Sanden compressor but I think all that is above the primary mounting plate where interference would exist. |
Different a/c brackets?
| All times are GMT -8. The time now is 12:25 AM. |
