Thumbs up 911 CV axles
I have a 1976 911S with a 915/71 transmission in it. I am working on this car for a friend and am trying to replace the CV axles after one of them broke off while driving. From what i have read the car is supposed to have the 100mm cv's with 6 8mm bolts? The car has the 108mm cv's with 4 10mm bolts and 2 roll pins. I have done a bunch of searches and am still not completely sure which parts to order. thanks for any help you might be able to offer!
Old 08-07-2014, 10:16 AM
Discseven's Avatar
Simba... I replaced my CV's on an '80 trans with host parts and thought the spec'd 8 x 50mm bolts were too short. I cannot tell you what the dimensions of my purchased CVs are at the moment. With the spec bolts, there were a few unused threads in the flanges. I went to 8 x 55mm class 12.9 bolts with lock washers and these consumed all the threads. No moon plates. I'll get under the car and measure the CVs if needed.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 08-07-2014, 01:55 PM
47silver's Avatar
4 bolt are 10mm grade 12 and 48 mm. 50 are too long they will cut into your banana arm. Do not reuse the originals. There is a very long thread on this on this site, that you must read,
Old 08-08-2014, 02:12 PM
108mm cv is correct
No - the 100mm CVs came out with the 77/78 SC models.
You have the better larger 108mm CVs which came before & after the SC.
Get a 108mm Kit from our sponsor.
I am curious - was it an inner or outer(wheel) CV that broke? When it broke , did it do any other damage?
Old 08-08-2014, 07:35 PM
irl irl is online now
irl's Avatar
Send a message via AIM to irl
Scroll down here
LINKS to helpful websites
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 08-08-2014, 08:23 PM
Tags
911 , cv axle , cv joint
