New Clutch - Starter Just Spins...
Just installed a new clutch kit in a friends '85 911 with a 915.
All done and reinstalled and the starter just spins. It sounds like the starter is spinning but not throwing out.
Pull the starter and check it on the floor, it's fine.
Is it possible the new ring gear is smaller? Pelican only lists one clutch kit for this car...
I am worried I have to pull the engine again...and I'm stumped now.
Old 07-07-2014, 09:15 AM
Just guessing here, but maybe check to see if it's wired correctly. Does it click when turn the key? If not, maybe it's simply that the solenoid isn't connected (??).
Old 07-07-2014, 10:03 AM
It is wired properly, it spins, you can here it.
It just doesn't grab hold of the ring gear to spin the engine.
Old 07-07-2014, 10:07 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Clutch.
The very same thing happened to me when a wrench omitted the ring gear.....No teeth....
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 07-07-2014, 10:43 AM
Confirm if the starter ring gear is installed. The other toothed ring gear on the flywheel (closest to the crankcase) is for ignition timing. It happens once in awhile.
Sherwood
Old 07-07-2014, 11:02 AM
I'd say the ring gear is still on the old flywheel.
Old 07-07-2014, 11:08 AM
The ring gear is there, I think.... I will confirm.
Perhaps Sherwood has nailed this...
FML. I thought we were done...
Old 07-07-2014, 11:21 AM
If it's there, here are some related starter ring gears (bolts directly to the pressure plate, not flywheel). Not sure of the differences. If the ring gear is new, check the paperwork/packaging to confirm:
Turbo: 930 116 230 02
Carrera: 911 116 230 02
G50: 950 116 143 01
You should be able to confirm the presence of a starter gear with a mirror through the starter opening in the bell housing.
When bench-testing the starter as it would be installed, the pinion gear should move forward as the motor engages. If the motor just rotates, the pinion gear linkage is malfunctioning.
Sherwood
Old 07-07-2014, 12:04 PM
I believe someone failed to recycle part #5 during this repair....
Thanks for your help. The only thing to be decided is if we pull the trany+engine (again) or just the engine.
Thanks for finding my stupid error.
Old 07-07-2014, 12:12 PM
Quite all right. You wouldn't be the first nor last person to do this. Other than this particular part, I'd estimate a misplaced component or fastener happens somewhere around 1000 times a minute.
At least you've stopped scratching your head.
Sherwood
Old 07-07-2014, 12:34 PM
Sadly, this is bonehead move #2. We left the snap ring off the third gear synchro and remembered just as we were closing the case up....
Tomorrow we will push-start the car and make sure the tranny portion is done.
Old 07-08-2014, 05:19 AM
Don't do it The clutch bolts will protrude through the back of the flywheel
Since Murphy seems to assisting you the bolts will saw through the case
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 07-08-2014, 05:43 AM
That might be good advice. I will connect the linkage and make sure I can get all five gears and reverse and begin the extraction.
Old 07-08-2014, 09:10 AM
