-   -   CIS to MFI conversion (http://forums.pelicanparts.com/porsche-911-technical-forum/81990-cis-mfi-conversion.html)
BK911 09-26-2002 11:30 AM
I have a 73.5T coupe that I am building up a slightly modified 2.4S MFI engine for. I know I need to change the fuel filter and maybe the fuel pump, but what about the wiring harness? I have the wiring harness for the MFI engine, can I just plug it into the console and Vroom vroom? Anything else?
Thanks!
BK
304065 09-26-2002 11:39 AM
Speed Switch
MFI cars have a "Speed Switch" in the console and an additional wire in the 14-pin connector that runs to the solenoid on the pump. The purpose of this is to cut off the fuel when the throttle plates are closed on overrun. Shouldn't be that hard to obtain/fabricate although the switch is a little pricey, like $250?
82SC 09-26-2002 11:45 AM
keep me updated on your progress
I have a 73.5 bare chassis and wiring harness...and I plan to add a MFI motor...
also Supertech in Costa Mesa,CA seem to be the self-proclaimed MFI experts...maybe they would know
MJ
BK911 09-26-2002 03:25 PM
Thanks John! I forgot to mention I have an MFI console as well. I guess what I was wondering is if the main wiring harness is the same for either car. Maybe I should look at the manuals!
82SC: It's probably going to be a couple of months before I install the engine. Too many other priorities right now! But I will keep you updated.
BK
