Be careful plowing off that pond. A guy doing that in the foothills west of Denver died when the plow broke through the ice. Of course Toronto is farther north, but this ice was at about 7,000 feet high.
And the temperature today in Boulder (and also Denver, I am sure) is in the low 70s (F). |
Well, its stayed below -15 for a couple of weeks, so no problems with the ice. My neighbor and I hauled 500 gallons of water down to the pond. the surface was great, the fire was warm and we had about 2 dozen down for the afternoon.
I plowed ahead last night and today and fininshed up stitching the front pan, supports, and seams. I moved back to a rust repair needed on both sides of the read door corners. The rails are in good shape, and I have replacement panels from RD that I am trimming back and fitting. I welded in a new section into the outer rails for more bracing and reinforcement... http://forums.pelicanparts.com/uploa...1422318643.jpg http://forums.pelicanparts.com/uploa...1422318652.jpg http://forums.pelicanparts.com/uploa...1422318666.jpg http://forums.pelicanparts.com/uploa...1422318708.jpg |
moving back now, I added some reinforcements to the torsion bar area. I found a number of pictures and threads here and used those as a guide.
I added gussets between the torsion bar and the tunnel... .http://forums.pelicanparts.com/uploa...1423449215.jpg ...and between the torsion bar suspension mount and the seat area.... http://forums.pelicanparts.com/uploa...1423449765.jpg http://forums.pelicanparts.com/uploa...1423449828.jpg ...also between the rear chassis cross mount and the chassis sheet metal behind the seats on the firewall... http://forums.pelicanparts.com/uploa...1423450347.jpg ...and of course the top strut mounts.... http://forums.pelicanparts.com/uploa...1423450684.jpg ...still planning on some more brackets/gussets in the engine bay across the corners |
I moved on to the front suspension and thought a lot about the strut towers. On hand I have a set of Elephant front monoball mounts, and I had bought a set of generic camberplates I was considering mounting to camberboxes I was going to construct.
After a lot of measuring, I figured out I would have to cut the tub's strut towers quite a bit to get the camberplates low enough to have the monoball low enough to have the shock not have a custom long shaft. Alternatively, if I could adapt the elephant plates and the towers in a way to get another 1 degree of camber that would make a few other things easier. I wouldn't screw up the geometry by cutting out and "losing" the pivot point for the struts. It might also be stronger and less work if I could make it work... So I found that if I grind ~2-3mm off the inside of each Elephant plate, cut the lip off the strut tower and enlarged the bolt and mounting hole I can get up to 5 degrees camber and 8 degrees castor. That will be plenty. I then set about making patterns, cutting, shaping and welding in reinforcements. I haven't fininshed boxing in the forward sides yet, but I am pretty pleased with the results so far. I did a lot of measuring and checking so it took about 10 hours of work plus maybe another 2 hours for the rest of the boxing hopefully later today. I will clean up the holes and corners before its finished... http://forums.pelicanparts.com/uploa...1427025977.jpg http://forums.pelicanparts.com/uploa...1427026004.jpg http://forums.pelicanparts.com/uploa...1427026033.jpg http://forums.pelicanparts.com/uploa...1427026050.jpg http://forums.pelicanparts.com/uploa...1427026065.jpg |
Cut the gutters
So I finally got brave enough to put the car back on the lift and start cutting and welding the gutters. I have never done this before, so I was really sweating that first cut. I found I was able to cut them much closer down and get much neater welds as I went along. I cut 6-8" sections at a time, first with an airsaw, then with an grinder, then airfile. I was really careful about getting as little heat into the metal as possible. Each weld, each pass with the file or grinder was followed with a wipedown with a wet, cool rag. I also found its really exciting if you hold a wet rag AND a MIG in the same hand when you weld :eek:
THere was quite a bit of seam sealer in teh folds of the metal, so picking it out was a pain. I found on the second pass with the welder that the metal burped and blobbed a lot less as the sealer had been brned off. I was religious about keeping it cool and cleaning the metal immaculately before welds. The welds arent pretty, but I am gradually grinding them back and neatening them up. The wife was just about in tears when I told her I was going to leave them like they were. I had her going for about 30 seconds... ANyway, this is about 16 hours into them, with glass blasting. http://forums.pelicanparts.com/uploa...1428884544.jpg http://forums.pelicanparts.com/uploa...1428884553.jpg http://forums.pelicanparts.com/uploa...1428884585.jpg http://forums.pelicanparts.com/uploa...1428884625.jpg http://forums.pelicanparts.com/uploa...1428884642.jpg http://forums.pelicanparts.com/uploa...1428884675.jpg http://forums.pelicanparts.com/uploa...1428884686.jpg My goal is to get the seams down to flush so very little filler is neaded.http://forums.pelicanparts.com/uploa...1428885079.jpg http://forums.pelicanparts.com/uploa...1428885087.jpg |
Isn't removing the gutters going to reduce the chassis rigidity? Help aero (A pillar, anyway), but remove what amounts to a beam section and replace it with a sheet?
Hi Walt,
I dunno, I am curious to see. Dont forget the 0.01lbs in metal i removed...that is in part why i added some gussets. |
The inner steel below the roof is a continuous piece still across so I dont imagine the folded gutters adds anything. But I am not an engineer.
I think I have read here that welding the gutters are the best thing you can do for ridgity after a cage.
Well, it is fun to speculate like an engineer. Here is what the A pillar rain gutter looks like in cross section.
http://forums.pelicanparts.com/uploa...1429057796.jpg You can see the rain gutter sticking out to the left. That has to stiffen the assembly some, both by increasing the width of the piece compared to it being cut off, and then with the L shaped end, resisting deformation in the crosswise plain. This stuff is spot welded by the factory. Perhaps cutting it off and mig welding continuously stiffens things? Just as seam welding spot welded members generally does (or is said to do)? But might these flanges, if seam welded, stiffen even more? |
I think that the drip rails are not spot welded, they are crimped on which is where I believe the added rigidity of gutter welding might come from.
I did mine and from what I can tell, nary a spot weld to be found on any of the "lip" section Dennis |
http://forums.pelicanparts.com/uploa...1429264655.jpg http://forums.pelicanparts.com/uploa...1429264662.jpg http://forums.pelicanparts.com/uploa...1429264669.jpg |
Nice Roland. Any more pics? How did you finish it, primer, filler, etc?
More pics you'll find in my thread: http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/634616-another-rust-combat.html |
Update from 4:20
Thanks all for your input. Also to Freddy H for his threads.
I had a few weeks holiday and caught a race at spa, some Mosport and Cayuga playdates. With the 3rd daughter on the way I better get it in now... I have - finished a set of carbonfiber struts across the struts - raised the rear inner suspension pickups - installed the front A arms - fit the rear coilovers - welded in new rear arb gussets - fabricated and welded in arb mounts - welded in rear quarter window frames - patched in rusted areas - gusseted the engine area frame and rear quarterpanels - cut the rain gutters off, welded, ground, welded, ground, welded, ground, welded, ground, welded, ground - sanded the sunroof patch back - Patched the floor - braced the reat towers - ordered tarett springarms - rebuilt the rear arms with monoballs and stripped them bare I'd guess 96 hours, plus or minus 15 minutes. Tomorrow am the kids have a playdate so I have 4 hours to finish sanding, degrease, metal prep and 2K eprime the roof. http://forums.pelicanparts.com/uploa...1434772001.jpg http://forums.pelicanparts.com/uploa...1434772055.jpg http://forums.pelicanparts.com/uploa...1434772069.jpg http://forums.pelicanparts.com/uploa...1434772097.jpg http://forums.pelicanparts.com/uploa...1434772116.jpg http://forums.pelicanparts.com/uploa...1434772125.jpg http://forums.pelicanparts.com/uploa...1434772148.jpg |
Flush rear window
Here's how I mounted my GT Racing rear window flange. Cleco'd and clamped in place with 3M Automix panel bonding. I am going to fill in over the gap so its completely flush, trim back the inner circumference of the flange and bond the lexan to that. I want a completely watertight/windproof seal as this will be a roadcar.
http://forums.pelicanparts.com/uploa...1435409259.jpg http://forums.pelicanparts.com/uploa...1435409309.jpg http://forums.pelicanparts.com/uploa...1435409330.jpg http://forums.pelicanparts.com/uploa...1435409331.jpg |
Mine is a coupe.
Shouldn't you plan for convenient service/replacement as well? Polycarbonate will scratch and visibility will change over time. No problem?
Sherwood |
Yes, i am going to use a silicon or rtv to glue the window to the frame. When i need to replace the window i can "saw" through the sealant with a wire and replace the window.
Got some motivation in the mail today...sorry a couple are sideways, I dont know why Pelican render them that way.
http://forums.pelicanparts.com/uploa...1435628008.jpg http://forums.pelicanparts.com/uploa...1435627875.jpg http://forums.pelicanparts.com/uploa...1435627883.jpg They are going to mbe mounted in these...CF fenders. They take some fitting but I am enthused...now back to the roof.... http://forums.pelicanparts.com/uploa...1435627874.jpg |
I got a bunch of stuff done, with a couple of track days sprinkled into so Im a happy guy.
I glassed in mounts for the headlights, then trimmed back the fender. Taped it over from the topside and glassed in the backside. The plan is to then trim back to the light lip so the trim piece snaps right into place. I spent a LOT of time aiming the headlights and positioning them when putting the mounts in place. Also got the front bumper fitted and mounts fabricated and glassed in. Maybe tomorrow I can cut the rear reflector panel out and fit the rear bumper. The headlights have really been a challenge. I am learning for sure. Here is a camera dump. http://forums.pelicanparts.com/uploa...1436677188.jpg http://forums.pelicanparts.com/uploa...1436677223.jpg http://forums.pelicanparts.com/uploa...1436677273.jpg http://forums.pelicanparts.com/uploa...1436677335.jpg http://forums.pelicanparts.com/uploa...1436677357.jpg http://forums.pelicanparts.com/uploa...1436677515.jpg http://forums.pelicanparts.com/uploa...1436677560.jpg |
So Ive never done anything like this before,, but so far I am pretty chuffed with the result. Overnight the glass all cured right and the tape comes away cleanly. I need to get a knife in around the edges to release the heaqdlight unit. Once that's done I will go back and clean up/finish the glass work with the headlight out of the way..
http://forums.pelicanparts.com/uploa...1436708177.jpg It will take some work to blend it in and look good but I am pretty happy with it so far. |
More filling and mounting of the passenger headlight. I hooked up the headlight to a battery and checked the light pattern. I got it centered and in the center of the headlight's adjustment range in both directions. I also checked the adjustment screws moved the pattern enough so I wouldn't have problems later.
The side shot with the nearside passenger fender cut and the farside driver's fender in the original 911 profile shows how much difference there is, though to my eye the car still very much has a classic 911 'face.' http://forums.pelicanparts.com/uploa...1437378353.jpg http://forums.pelicanparts.com/uploa...1437378453.jpg http://forums.pelicanparts.com/uploa...1437378423.jpg http://forums.pelicanparts.com/uploa...1437378452.jpg http://forums.pelicanparts.com/uploa...1437378461.jpg |
Got the second light positioned and the mounts glassed in. I hope to finish the first layer on the backside of it tonight.
http://forums.pelicanparts.com/uploa...1437429948.jpg http://forums.pelicanparts.com/uploa...1437429991.jpg Also got the rear bumper fixed in place. I cut out my rear reflector panels and fit the bumper against the flange I formed. Then I tucktaped the edge, and added release agent and put a first layer of glass in to form a lip on the bumper that will bolt onto the body flange. http://forums.pelicanparts.com/uploa...1437429995.jpg http://forums.pelicanparts.com/uploa...1437430003.jpg http://forums.pelicanparts.com/uploa...1437430005.jpg I have to compliment GT Racing on these fenders, bumpers and hood. Everything is fitting right on with very little massaging. Very light with good finish. He did mine about 2 years ago, if I recall it was 2 layers carbonfiber, 1 layer Kevlar? |
So this is my build thread now I guess...
Spent 4 hours blasting the tub today. Another 6 hours stripping paint and filler from the doors, forming the metal edge around the doors, filling in the mirror holes and got onto the dash. I want a very simple dash and it doesnt get simpler than this. Almost all the vents are bloched off, heater controls, switchgear, lights, radio, everything is blocked off and glassed behind or filled in. I got 3 layers of glass and 3 layers off metal filler on tonight. http://forums.pelicanparts.com/uploa...1438575101.jpg http://forums.pelicanparts.com/uploa...1438575135.jpg http://forums.pelicanparts.com/uploa...1438575155.jpg I glassed in the bumpers and mounts, welded on brackets on the car and blasted them for primer. http://forums.pelicanparts.com/uploa...1438575201.jpg http://forums.pelicanparts.com/uploa...1438575225.jpg http://forums.pelicanparts.com/uploa...1438575347.jpg I have a set of plastic lightweight front and rear turn signal light boxes from SMC. |
The lower dash and up around the instruments will be one continuous surface in paint. The upper dash will require some work, involving foam and fiberglass finally finished in alcantara.
So my bumpers are mounted without the use of the OEM bumper mounts or the towhook. Any reason the areas in red cant be cut off? They look like about 5 lbs of dead weight right at the worst space.
I did a bunch of bracing to the rails/across the corners in the engine bay. Those mounts dont look like they add any bracing and are now superfluous? http://forums.pelicanparts.com/uploa...1438576476.jpg http://forums.pelicanparts.com/uploa...1438576507.jpg No rear reflector panel needed. http://forums.pelicanparts.com/uploa...1438576579.jpg Front fender and bumper mounts. Front roll bar mount reniforcements welded in and blasted back for primer. THe backsides of the seam welds dressed for primer. http://forums.pelicanparts.com/uploa...1438576623.jpg Patch panels all stitched in, including torsion bar covers. http://forums.pelicanparts.com/uploa...1438576637.jpg Back on the rotisserie and front ready for washing/degreasing/primer. http://forums.pelicanparts.com/uploa...1438576650.jpg Strut towers braced in, cleaned up and almost ready for primer. I need to patch in and shape the camber/caster holes a bit and make them pretty. http://forums.pelicanparts.com/uploa...1438576654.jpg Pedal area. There is a thick plate welded in hte outside in front of the cluster mount to encourage a firm pedal. http://forums.pelicanparts.com/uploa...1438576686.jpg http://forums.pelicanparts.com/uploa...1438576692.jpg Front oil cooler ducting cleaned up and ready for primer, seamsealer. http://forums.pelicanparts.com/uploa...1438576698.jpg |
Another day of media blasting, degreasing and primering the raw metal. Wife wanted the garage powerwashed out too so that was another 3 hours...
http://forums.pelicanparts.com/uploa...1438655678.jpg http://forums.pelicanparts.com/uploa...1438655811.jpg http://forums.pelicanparts.com/uploa...1438655812.jpg http://forums.pelicanparts.com/uploa...1438655825.jpg http://forums.pelicanparts.com/uploa...1438655919.jpg http://forums.pelicanparts.com/uploa...1438656120.jpg http://forums.pelicanparts.com/uploa...1438656175.jpg http://forums.pelicanparts.com/uploa...1438656194.jpg http://forums.pelicanparts.com/uploa...1438656209.jpg |
What kind of mig welder do you have? pic?
Lincoln 180c with 75/25 gas. Its in the background in the 4th pic from the bottom.
Continued welding in new lips for the 993 flush-mount rear quarter window seals. I was able to play with the size of the opening so that I think it will end up flush with the body all around without altering the seal at all. Lets see. The window will be from a piece of makrolan I have.
http://forums.pelicanparts.com/uploa...1439677112.jpg http://forums.pelicanparts.com/uploa...1439677270.jpg |
Another 10 hours on fabricating and welding in new quarter window lips, oscillating scraper and cup brush on the bottom
http://forums.pelicanparts.com/uploa...1440633827.jpg http://forums.pelicanparts.com/uploa...1440633838.jpg http://forums.pelicanparts.com/uploa...1440633857.jpg http://forums.pelicanparts.com/uploa...1440633890.jpg http://forums.pelicanparts.com/uploa...1440633934.jpg Just noticed tonight Evercoat Metal 2 Metal features a 911 on the label... http://forums.pelicanparts.com/uploa...1440633820.jpg |
Its been a while, a good bit of progress to report. Underside is finished, Frunk and engine compartment are painted and done. Tonight I did a few coats of filler on the lower dash. I foamed in the upper dash, shaped and sanded it back then put a layer of fiberglass on. When that sets I will put some foam on and finish with alcantara...
http://forums.pelicanparts.com/uploa...1442723856.jpg http://forums.pelicanparts.com/uploa...1442723880.jpg http://forums.pelicanparts.com/uploa...1442723935.jpg http://forums.pelicanparts.com/uploa...1442723939.jpg http://forums.pelicanparts.com/uploa...1442723977.jpg http://forums.pelicanparts.com/uploa...1442723978.jpg http://forums.pelicanparts.com/uploa...1442723987.jpg |
Replacing the dual wipers with a single wiper
Here's another rabbit-hole project I am building into her.. I have seen a few threads on lightening the existing wiper and linkages, and mention of the use of a 944 rear motor (NLA) and I have seen those 79-80 Sciroccos with single wipers.
The route I am trying has the goals of 1. passing inspection, 2. keeping my wind shield clean in light rain for limited time (ie not expected to deal with huge downpours, ice or now) and 3. lightweight and 4. accomodate a single wiper in fitting in the the streamlining I have done on the rest of the car. I settled on using a rear wiper motor from a Jeep, across their range from the 90's through the 00's. Interestingly it arrived and is a Valeo unit. So before anyone gets all insulted for putting Jeep parts on a Porsche, its the same manufacturer that makes many of our alternators and regulators. THe unit is very small and lightweight. WHen I get a chance I will dig up the original motor and linkage and compare the weights. The dimple the wiper arm sticks through the body fits the Valeo unit perfectly. Of course I have 2 of the dimples to accommodate the original wipers so having confirmed there is plenty of room under the dash for a bracket and the motor, I plan on cutting out both dimples and relocating one of them to the center of the car. Then patching in the two old arm hole. http://forums.pelicanparts.com/uploa...1443972565.jpg http://forums.pelicanparts.com/uploa...1443972602.jpg http://forums.pelicanparts.com/uploa...1443972738.jpg http://forums.pelicanparts.com/uploa...1443972749.jpg |
| All times are GMT -8. The time now is 05:34 PM. |
