Fuse Box Loose Wire
Im trying to diagnose why my passenger window doesnt go down (its not the switches) and noticed that the black red wire in the fuse box was loose
can somebody tell me what its for? or what fuse it belongs to?
Artur
Old 07-04-2014, 06:46 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Model/Year?
Who Will Live... Will See
Old 07-05-2014, 02:46 AM
1980 911SC coupe
I should mention that I thad a factory installed Clifford Alarm system that was removed
Old 07-05-2014, 05:13 AM
Heck, I’m only 5 not 71!
targa80's Avatar
can you provide a straight on picture of the whole fuse assembly? I have been knee deep into the wiring on my 80SC and will research where the black with red strip wire could be coming from. The power windows are associated with relay 5 and fuse 21 You will need to disconnect the battery and ohm out the circuit to see where the disconnect is if it is not the switches or motor that controls the operation of the passenger side window. That is assuming that the drivers side is fully functional.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 07-05-2014, 06:10 AM
JJ 911SC's Avatar
The Anti-theft from the factory was a Black/Red but it does not show up on the fuse box layout.
Old 07-05-2014, 06:12 AM
Platinum Member
dad911's Avatar
Is that connection near the top of pic (black wire) wrapped in duct tape?
Old 07-05-2014, 06:48 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
fuses.
I would start with fuse #21.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 07-05-2014, 07:11 AM
wire
Here are a few more pictures
Fuse #21 is fine, the drivers side window works great. The passenger side window would work and all of a suddent not work, then work again. I replaced all the windown switches that controll the passenger window and nothing
That loose black wire/red wire was joined with a red wire then split, where the red wire wend to fuse #17
Old 07-05-2014, 07:36 AM
switches.
When you write "nothing", is the pass window not working at all?
Please be more specific.
1986 911 Targa.
Only in L.A.:
Old 07-05-2014, 07:46 AM
right, at the moment its not working at all
before it was intermittently
Old 07-05-2014, 08:06 AM
switches.
Not even from the driver's side switch?
1986 911 Targa.
Only in L.A.:
Old 07-05-2014, 08:09 AM
The drivers side switch (that operates the passenger window) toggled a bit wierd, so originally I thought the drivers side switch was the problem. I replaced it and the pas. widown still didnt work. So then I replaced the passenger side window switch, no change
Old 07-05-2014, 08:14 AM
targa80's Avatar
It seems at this point you need to buzz out the wiring for the passenger side window starting from the drivers side switch. Here is the circuit boxed in red that would apply. In my opinion you have either an intermittent connection (check the contacts for corrosion especially the ground side) or you may have inadvertently miss wired one of the switches or used the wrong switch in the wrong location. I think this because I myself have done that and things just go down hill from their.
Pat Henry
Targa80
Old 07-05-2014, 09:13 AM
thanks, this helps
Looks like the I connected the drivers side switch correctly
its probably a ground issue..
Old 07-05-2014, 09:46 AM
targa80's Avatar
I just checked the part number I have on the driver side passenger switch (02) and it is an older part that was superseded by the (03). The parts manual in PET calls for 3 of the (03) switches. Mine works with the one (02) switch so as they say "if it isn't broken don't fix it".
Pat Henry
Targa80
Old 07-05-2014, 09:51 AM
targa80's Avatar
It seems my power window switch layout does not match the schematics. My system is functional but is color coded wrong between the driver side passenger switch and passenger side switch. I have corrected the below drawing and added the pin numbers to each switch. I will correct the wiring on my car to match the schematic.
Pat Henry
Targa80
Old 07-05-2014, 05:19 PM
I will have to take it to a mechanic, to see where the discontinuity is
dont have a voltmeter or knowledge for that matter to get this resolved
Old 07-06-2014, 07:31 AM
Switch wiring.
I took these pics & these are the confirmed connections for our '86.
If you only replaced the switches, please re-check the color codes/pins.
Good luck,
Gerry
1986 911 Targa.
Only in L.A.:
Old 07-06-2014, 07:58 AM
Update:
the drivers window all of a sudden stopped working also. so both windows were out
Determined that I wasnt getting any power to fuse 21. So i jumped fuse terminal 20 (AC Blower) and the Drivers window now works.
The Passenger window was getting power. I stripped the door panel, and gave direct power to the motor. The window motor is dead.
so I will have to replace that.
Old 07-15-2014, 05:53 AM
