-   -   Another Problem... (http://forums.pelicanparts.com/porsche-911-technical-forum/82075-another-problem.html)
Wayne 962 09-27-2002 03:57 AM
Another Problem...
Well, I've found many errors in the spec books, but I've just come across some missing information! Anyone have any idea where I might find the following valuable information?
Piston Top Ring
- Groove Dimensions / tolerances
- Ring Dimensions / tolerances
- for all 911s 1975-89
Piston Middle Ring
Piston Oil Seal Ring
Cylinder to Crankcase Dimensions
- Shaft
- Bore
Cylinder to Cylinder Head Dimensions
- Shaft
- Bore
-Wayne
john walker's workshop 09-27-2002 05:42 PM
the ring grooves vary between mahle and schmidt in the early years, and are mostly 1.5/ 1.5/ 4.0 in later years. the ring side clearance and wear limit is listed in section 1, page 6.1-4/1 in the 1st volume of the factory repair manuals. the end gaps are also listed on the previous page.
on the cylinder/crankcase dimensions, what do you mean by "shaft"?
Roland Kunz 09-30-2002 05:25 AM
Hello
Errors in the factory spec books ( typen, masse, toleranzen ) ?
Most specs are covered and descriped in the factory manuals but you need the complete set from 65 on ( if something was covered in the previous volume it will not show up on later volumes, only if something changed ). Just look for the 0 sections ( technical data ) and for the spec section in each undersection.
Grüsse
Wayne 962 09-30-2002 12:38 PM
Thanks - but I've scoured all of the factory manuals, and tech bulletins. They omitted this stuff from the later spec books...
-Wayne
pwd72s 09-30-2002 05:44 PM
Wayne? I think Roland may know more, when it comes to details of more than a few years ago, than 95% of the people at the factory....he's a valuable resource, methinks...
