Oil temp sender connector terminal
This seems like a dumb question but what size/type is the oil temp sender round connector push-on terminal? I have small, medium, and large sizes and NONE of them fit! It's bigger than the large size. Is there an extra-extra large size available somewhere?
On which car?
On my 3.0 I recall just pushing a bit harder did the trick.Or use a screwdriver to slightly enlarge the gap. |
I have them. PM me with your info and I can mail you one or two.
Or,
Brass .312” Flag Receptacle Here: http://www.easternbeaver.com/Main/Elec__Products/Terminals/Open_Barrel/open_barrel.html $20 minimum I believe from Japan. Mouser has similar but not in brass. Sent from my iPhone using Tapatalk |
The .312 terminal is the same that is used on an H4 headlight.
Motorcycle Spade Terminals Part # YFST1416N Open Barrel I also have 2 or 3 leftover from when I converted to ceramic H4 connectors a few weeks ago, so if you can wait, pick them up when you come by for the muffler. Or, if you happen to be running H4 bulbs, you can upgrade the connectors with ceramic, and have them toss an extra female terminal or 2 in the order: Headlight connectors Get the orange covered ones. |
They are in the mail to you. :)
| All times are GMT -8. The time now is 09:42 AM. |
