Oil temp sender connector terminal
This seems like a dumb question but what size/type is the oil temp sender round connector push-on terminal? I have small, medium, and large sizes and NONE of them fit! It's bigger than the large size. Is there an extra-extra large size available somewhere?
DD summer/winter: 2000 Boxster S
DD spring/fall: 914-6 w/ 3.0L SC Dual Webers (For Sale)
http://imgur.com/a/k0Wtl - My 914-6 Build/Project Story
Old 07-15-2014, 07:44 PM
tazzieman's Avatar
On which car?
On my 3.0 I recall just pushing a bit harder did the trick.Or use a screwdriver to slightly enlarge the gap.
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 07-15-2014, 08:03 PM
ROW '78 911 Targa
timmy2's Avatar
I have them. PM me with your info and I can mail you one or two.
Old 07-16-2014, 08:54 AM
ROW '78 911 Targa
timmy2's Avatar
Or,
Brass .312” Flag Receptacle
Here:
http://www.easternbeaver.com/Main/Elec__Products/Terminals/Open_Barrel/open_barrel.html
$20 minimum I believe from Japan.
Mouser has similar but not in brass.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 07-16-2014, 09:14 AM
The .312 terminal is the same that is used on an H4 headlight.
Motorcycle Spade Terminals Part # YFST1416N
Open Barrel
I also have 2 or 3 leftover from when I converted to ceramic H4 connectors a few weeks ago, so if you can wait, pick them up when you come by for the muffler.
Or, if you happen to be running H4 bulbs, you can upgrade the connectors with ceramic, and have them toss an extra female terminal or 2 in the order:
Headlight connectors
Get the orange covered ones.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 07-17-2014, 08:59 AM
ROW '78 911 Targa
timmy2's Avatar
They are in the mail to you.
Dennis
Old 07-17-2014, 09:11 AM
