Taking it apart is easy
Insane wipers = NLA windshield wiper switch?
There have been a number of threads about windshield wipers that suddenly turn themselves on, and then cannot be turned off. That's what I've got.
Here's what I've done: 1. Found damaged ground wire and patched this. 2. Cleaned ground contact and reassembled everything. 3. Result = Wipers no longer worked at all - no uncontrollable running, no normal running. 4. Took the whole business apart again and further cleaned contacts, reassembled. 5. Result = Wipers running and won't shut off, same as before. So, what should I do next to analyze? These switches for '74-'75 are NLA. Some pictures: Melted and abraded ground wire. ![]() Fixed ground wire.
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com |
But, I don't care to replace parts as a diagnostic method. How do I go about testing the switch?
Brew Master
OOPS! you're in Quebec, I'll need to see how much shipping is. Sorry. Let me know if you're interested. BTW, isn't there a wiper relay up front in the trunk area? Last edited by cabmandone; 07-15-2014 at 02:35 PM.. |
I'd still like to test my existing switch, though. I don't know about a relay in the trunk - where is it?
Keep checking the classified. I recently bought a new switch for my '74 for $50 and it worked perfect. I had issues with my old wiper switch, the wipers turned on every time I went over a bump.
Jerome,
I have a '74 and I'm assuming you do to. I noticed that in your photo, you don't have the intermittent switch that is usually on the dash (your photo has a plug). I'm wondering if you don't have the intermittent knob, then maybe someone has made adjustments to your car and that could be contributing to your issues?? |
Thank you. I'll do that. Lucky you.
Brew Master
I thought the knob above the plug was the intermittent. What is it if it's not the intermittent wiper? BTW, I can do $50 shipped to Vermont. I'll get you a pic of it tomorrow. If it doesn't work, put it in a flat rate box and send it back, I'll refund all but the shipping out. $10 for a test switch might be money well spent.
So the switch you have has the same part number as mentioned by me above? If so, PM me and let's work something out.
Here's a quick photo of my dash knob. Also check your owners manual as it usually states "optional items". I was going to look at mine but I seem to have misplaced the manual.
Intermittent wipers were originally an option and the switch was located on the dash face, to the left of the ventilation controls. Porsche moved it up higher, to the instrment cluster, later.
JR |
