Voltage on Black / Purple Tachometer Wire
Folks,
Tossing this out to the wider community of folks who have worked on 911 tachometers. When I connect a multimeter to the black/purple wire that comes from my tachometer - I get a voltage reading of ~ 10v (key on, and the BLK/PPL wire only connected back to the vehicle tachometer / bare open ended wire - not connected to a RPM signal source). I assumed that the BLK/PPL wire would receive a voltage signal from a source (CDI, dizzy, signal generator etc.) - as such I'm surprised to find the wire has voltage which appears to be coming from the vehicle's tachometer. Anyone know if this is normal, or is something mixed up with my tach wiring? Thanks, Gordo -------------------------------------- For background: I'm troubleshooting a problem I'm having getting RPM to work correctly when connected to my vehicle tach and the LM-2 wideband meter. RPM Input to Innovate LM-2 from XDi Igntion
Don "Gordo" Gordon '83 911SC Targa |
ROW '78 911 Targa
What terminal is the black/purple wire connected to on the tach?
Should be TD with the white/red from the rpm limiter. Is the rpm limiter switch imposing a voltage on it? Pull the limiter wire and see if it goes away.
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 08-01-2014 at 01:49 PM.. |
Gordo,
The voltage on the TD wire at the tacho is normal. The TD wire does not 'drive a voltage to the tacho', rather the CDI box is a current sink for the tacho. With the wire disconnected, you'll read more or less the supply voltage (12v) on the TD pin on the tacho. With the wire connected and the engine running you'll see a square wave of approx 6.8 volts peak. Why 6.8 volts? Because that is the internal voltage of the circuit in the CDI. Basically, the CDI box pulls the tacho TD line to ground to create the signal. |
Great Info
Johnny H - great explanation, thanks.
Timmy2 - not sure where the BLK/PPL wire actually terminates, I I tapped it at wire harness in the engine bay. Gordo
You shouldn't be measuring the voltage with a voltmeter, you must use an oscilloscope.
HELP! tach died and I need to know what can replace it!
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Black/violet wire terminals.......
Gordo, The black/violet wire is connected between tachometer terminal TD and CDI terminal TD. Please refer to circuit #95 for the USA SC factory wiring diagram. Tony |
Agree
I simply found a static voltage in a location I didn't expect. Gordo
Don "Gordo" Gordon '83 911SC Targa Last edited by Gordo2; 08-02-2014 at 07:07 AM.. |
