Turn Signal Issue on 1988 911 cab???
All turn signals work fine until I turn headlights on. While the both sides continue to work, the left side all flash very fast. Could it be the flasher even though the right side are not affected? Where should I look first?
1988 911 Cab; 2012 997 TTS; 1999 Jeep Wrangler; 1970 Honda CL100; 1972 Kawasaki H2; 1972 Suzuki TM400; 1973 Kawasaki F11-250; 2007 Ducati SportClassic 1000; 2013 KTM 350EXC
Old 05-16-2015, 05:06 PM
No ideas?
Old 05-17-2015, 11:35 AM
RETIRED
Joe Bob's Avatar
Likely a bad bulb in the circuit someplace. Are all the marker lights and such working? Also bets to check and clean grounds. Do you have a Bentley manual or a wiring diagram specific to you MY? Pelican has them online.
2012 ML350 3.0 Turbo Diesel
Old 05-17-2015, 11:53 AM
