Caveman Hammer Mechanic
Rebel Racing
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 Last edited by ClickClickBoom; 02-11-2014 at 08:37 PM.. |
Like it sez, got 4 of these beauties from Clint, nice packaging great service, called him instead of ordering on line since my Mac and Firefox mangled his website, Safari works great instead. Ordered them, got them nearly as quick, and as they were sitting on my bench mocking me for not installing them immediately. Got out the jack and stands and a block of wood and floor jack and had the rears in lickity-split. The mounts from RR are a little thicker than the stockers so the 8 8mm bolts had to be replaced if I was gonna use some NLX8 Nord-Locks instead of the ever so, low tech split locks.
I dumped every hardware can I had looking for the right length (1") Grade 8.8 bolt for the installation. Found 7 the right length and 1 more slightly longer and it slid into place like all good German hardware should. Decided to christen the new mounts out with a run up the Boulder Creek GP course, did all the stuff that made the stockers(mounts) act goofy. With the Seine Systems gate shifter, the Porsche Short shifter kit, and Stomski coupler the shifting was almost flawless, if I loaded the car up in a corner and tried to up shift it would do it but I had to be very precise. With the RR blues in place, I couldn't get the shifting to do any of the old shennagians. NICE! Road noise increase was negligible since I have the sound pad removed and a Dansk Sport muffler installed, I couldn't hear anything extra except a hint of gear noise. All in all a 2 banana job, only because of the jack and stand and would have taken about 1 hour if I didn't have to dig for the new hardware. The original copper based anti seize was on the main bolt, after 30 years! A side note the bottom mount cup washer was corroded quite a bit. Pics to follow! The bottom washer showing significant corrosion: ![]() The motor mounts: ![]() Trans mounts: ![]() Hola eric
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Air Cooled
Nice!!!
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat" - - '99 Honda VFR800Fi, '98 Honda SuperHawk '88 Honda Hawk GT, '77 Honda CB750K Cafe '69 Honda CL350 |
Is there a washer with that trans mount?
Todd
'81 SC |
The washer with the stock mount is flat and too large for the RR washer, I tried it and the bolt was 2-3 threads short of protrusion from the bottom of the mount. Without the stock washer I get, about 1+ thread protrusion. The stocker was flat and had no locking action, so I did not use it.
I was referring to #4 in the picture.....
Yes, it is included with the RR mount.
I will say that all the mounts are the same, so that's easy, I ordered some new hardware from Belmetric new 8.8 metric hardware will look nice and the zinc will be fresh.
I was thinking about the mechanics of this mounting system. The engine and trans hang from the mounts and the bolts provide a solid axle for the insulator to work against. The 12mm center bolt has only tension to prevent withdrawal from the car body. The engine mount bolts have potential protrusion through the crossmember and the possibility to secure with a nut on the lower bolt for additional security. The trans mount threads into the body with no access that I can see for additional security.
Well,
I was bombing around today, put some new plugs in, went to O'Reilly to chase down a dizzy rotor. Was poking around in the engine bay and noticed that one of the bolts, the orange torque booger was cracked? WTF? Broke out the torque wrench and 19mm socket, all the bolts took almost a whole turn to get to 58 lb ft. Re-boogered them and will check soon.
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 Last edited by ClickClickBoom; 02-13-2014 at 09:42 PM.. |
Bolts are tight as a drum, looks like checking after initial torque and drive is the new order!
non-whiner
Don't get too hung up on a cracked booger. The bolt will flex slightly under engine torque as the mount does its job. The bigger "tell" is when half the booger is on the bolt and the other half is on the washer 90 degrees away.
"Too much is just enough." |
The only reason I can think of for the loose bolt might be the compression of debris under the bolt stack being worked out via vibration, or the anti-seize, who knows exactly, but the bolts are still tight and boogers intact after re-torquing. My CVs which had new 12.9 bolts and Nord-Lock NLX washers are still tight as a drum as well.
Porsche fanatic
Eric or anyone else who's done this:
I installed the RR tranny mounts last night and I noticed that the blue nylon insert at the top makes it thicker than OEM mount and there is a 1/2" gap between the mount and body. You can see this in your picture above of the tranny mount. Obviously, this reduces the amount of thread in the 2 large 19mm bolts. The issue I'm having with this is the center support with the 4 little studs with the flat spacer does not touch the tranny! Did you have this issue and how did you deal with it? 3 of my studs were missing and I couldn't find any at 11pm last night so I was going to replace with M8 Allen bolts, anyone see any issues with this? I was going to re-install the factory Sport mounts I have since I'm not comfortable with the gap unless I hear this is normal for these mounts and my tranny is not going to fall out at 140mph at Watkins Glen next week.
'56 Speedster Guards Red '74 911 IROC- 3.2L, 22/28 tbars, 22 sways, Bilsteins, Big Reds, Seineshift, headers/M&K, slicks, 17" Fuchs, SW '95 993 -H&R coilovers, turbo sways, GT2 wing, Fabspeed '74 911 Targa, 87 944T, '75 911 Anniversary Edition-sold Last edited by jager911; 07-16-2014 at 05:10 AM.. |
Porsche fanatic
p.s. is a good idea to use Loctite blue on the tranny bolts and where can I find the torque check 'booger'?
'56 Speedster Guards Red '74 911 IROC- 3.2L, 22/28 tbars, 22 sways, Bilsteins, Big Reds, Seineshift, headers/M&K, slicks, 17" Fuchs, SW '95 993 -H&R coilovers, turbo sways, GT2 wing, Fabspeed '74 911 Targa, 87 944T, '75 911 Anniversary Edition-sold |
Porsche fanatic
Did you have a space there as well where you may have added washers to have positive contact with center of tranny? I thought I got the wrong part but I see from your picture, you have the same space I have above the mounts where the 19mm bolts meet the body.
Max Sluiter
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance Last edited by Flieger; 07-16-2014 at 08:34 PM.. |
Porsche fanatic
