Bollweevil
?? On Installing the Fan on the Alternator
Installing my newly powder coated fan on the newly rebuilt alternator. I hope this makes sense:
Question: do you just push the fan down on the alternator shaft as far as it will go using the big nut? I really didn't pay attention to where the fan was seated when I pulled it and definitely do not want to seat it to far if that is possible.
Jack
74 911 Coupe
2.7L - K21 Option - S suspension
Old 07-19-2014, 07:58 PM
schulr's Avatar
Send a message via Yahoo to schulr
The fan sits right on the alternator with the large 22 mm bolt on the outside. Follow this link for some good picture of an alternator rebuild. Try a search as well as there r many topics written on this subject. I just completed mine last month.
Bob
2009 C2S cabriolet
1987 Targa - sold
2003 BMW X5 - sold
Old 07-19-2014, 08:30 PM
schulr's Avatar
Forgot the link.
1987 Alternator + Fan/Housing (Vertex) Replacement - Rennlist Discussion Forums
2009 C2S cabriolet
1987 Targa - sold
2003 BMW X5 - sold
Old 07-19-2014, 08:31 PM
I wouldn't use the nut (NOT bolt) to seat the fan. The threads weren't designed for that purpose. It should slip on with a little force. If was properly powder coated the inner surface of the mounting hole should be paint free. If not, you're gonna have to remove the paint from that area, and without damaging the surface in any way.
The Cap'n
Old 07-19-2014, 09:08 PM
Bollweevil
The Cap'n
The fan went on fairly easily, I'm just not sure it is fully seated and wondered should I use the big nut to pull it down until it won't go down on the shaft any more ? i.e. is the fan fully seated when it bottoms out on the shaft ?
Jack
74 911 Coupe
Old 07-20-2014, 04:30 AM
I wouldn't use the nut to cinch the fan down as it should just slide down on the shaft with a slight feel of a interference fit.
Just look closely at the fan to ensure their is no powdercoat on any mating surfaces.
If you are in doubt check the fan pulley is aligned with the crankshaft pulley.
Cheers
Bill
1977 Carrera 3.0
This much fun must be illegal!
Old 07-20-2014, 06:11 AM
