So how did your 911 surprise you today?
As I am quickly finding out by our new to us 78 SC, each week and or day brings me joy and pain. Driving it everyday is waking up aches and pains that this little pony has.
So my question to the forum is as follows: What are the things that "surprised" you today? I'll kick it off by sharing what I discovered this morning getting ready to run some errands. Needless to say I took another car. This is the only Porsche I've had a chance to drive on a semi regular basis, so I wouldn't know any different on its handling. Anyway, walked out and one look at my front end and I knew something was amiss. My steering wheel orientation. ![]() My r/front wheel orientation that corresponds with my steering wheel. ![]() ![]() L/front wheel orientation(rutrow) that doesn't correspond ![]() ![]() Sent from my iPhone using Tapatalk
"What the hell is an Aluminum Falcon??" -Palpatine (Robot Chicken) 1978 911SC Targa Working Projects: 1968 912 Last edited by bugstrider; 07-22-2014 at 10:29 PM.. |
Looks like an alignment is of the order.
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
Functionista
Common malady known as looseboltitus. Only known cure is laying under one's car and putting a wrench/socket etc on every fastener that can be reached. Especially steering and brakes.
Mine surprised me by rolling over 90K despite never having a pulled head stud (yet). Driving it 40 miles daily.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
Driver
How did my 911 surprise me today?
Mine didn't start.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
weekend wOrrier
Pulling into my driveway yesterday afternoon, my car developed a screeching like a failing throw out bearing. While mentally preparing a "while you're in there" thread, I realized the screeching was my neighbor's tractor mowing nearby. Laughing at myself, I remembered older cars makes you hyper-aware of noises. Too aware!!!
Troll Hunter
Mine screamed from 4000 RPM's to 6000 RPM's from 4th to 5th, windows down and sunroof open, and since my speedometer doesn't work, I have no idea how fast I was going, but it was fun, and surprising!
1978 SC Coupe, Gris Argent Metallic Silver 1988 FJ62 Blue/Gray 2020 M2 CS |
Here is my little joy........
Put key in ignition, turn, fuel pump clicking, starter not turning (battery is fully charged). Turn off..... turn on again, fuel pump clicking, no start..... Do this 'turn on, turn off' a few more times. For no reason, Starter turns, car starts, drive off..... Later that evening, turn ignition key, car starts right away. Drive off. This happens occasionally (once every 30 or so times). Ignition issue? Started issue? Ground issue? ??????
Jim '75 Targa '77 MG Miget (Sold) '70 MGBGT (Sold) |
1987 911 Carrera |
Nah, that's just Ackerman ;-)
Todd
'81 SC |
Yea, there is no rhyme or reason when, why it happens. But, Since this is my daily driver, I have to deal with it until I can find a few days off to fully track down the problem(s).
I too have experienced the random no start issues Jim. It happens very seldom. Thus far I've just accepted it as part of having an old car.
Air Cooled
Hahaha yes! Looks set up well...for a drift car.
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat" - - '99 Honda VFR800Fi, '98 Honda SuperHawk '88 Honda Hawk GT, '77 Honda CB750K Cafe '69 Honda CL350 |
The starter gets a dead spot inside the motor. Quick check next time it happens is to bump start it. If you can get it rolling, pop the clutch while in first. Should start right up. If so, you need a new starter.
BTW you can bump start going backwards, provided the transmission is in reverse. BTDT Quote:
There is a thread on this problem. Sorry I can't find it right now. I also have this problem my solution was to run a starter button from the battery too the starter. With ignition key turned on I press button to start car. My problem is the ignition switch is not sending the power to the starter.
1986 Porsche 911 Targa 1983 911 sc 2015 WRX |
How did it surprise me? Well just by being so thrilling and fun to drive. the new high end CDI really makes it run so well. Makes up for the final gaps in the MFI being too rich in a few places.
I like my new clock/volt/oil temp gauge and the AFR gauge built into the old clock opening: ![]() ![]() What could be better than an empty Mulholland highway early on a Saturday AM. ![]() ROCK STORE ![]()
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
The 70 surprised me by allowing me to reinstall the carbs without skinning a knuckle or dropping so much as a washer much less a tool. I'm amazed.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
86FlatSix
My cousin and I went for a drive and after having coffee, we decided to part ways. When I was about to pass his 87, I gave the usual beep and wave and guess what? The horn acted up and wouldn't stop, lol. I pulled over as I passed him with the horn balsting away until I pulled over to the shoulder. It took me a good 2 long minutes which felt like forever in this kind of situation before what for ever reason the horn stopped. Whew! I took off the steering wheel and found a splintered wire. Wrapped it with electric tape and back to regular programming..I guess I was not the only one surprised on that busy street...lol
74 BMW 2002 (rust rocket) 86 911 Coupe (weekend warrior) 09 997.2 C2 (semi-daily) |
Has anyone resolved the Key not activating the Starter 83 and Below 911?. This is the thread about the ignition problem hope it helps.
Also while you're in there this is something you should take care of too.
Dash Lighting Fuse Installation
