bcheney's Avatar
G50 install question
I have mated up my G50 to the rebuilt 3.2. I am doing this solo so it took be a while to get the tranny to slide into the clutch. Now that I have the nuts snugged up I noticed that the Clutch Shaft Arm doesn't seem to be in the right place. I am pretty sure I installed it correctly. I am not sure that the arm is properly aligned with the T/O bearing. The arm does not pivot freely at this point so I know I have a problem. Have a look at the pics and let me know what I should do next.
08 Cayenne V6
89 911 Targa Carrera 3.2
75 914-6 Conversion
Old 07-24-2014, 05:56 AM
group911@aol.co's Avatar
Looks like you missed the groove in the T/O bearing. Back the trans off and start over.
Thanks,
Bob
group911@aol.com
Old 07-24-2014, 07:34 AM
porsher
aston@ultrasw.c's Avatar
Are you familiar with the install process, sorry if im telling you something you already know.
To start, the release arm is positioned on the engine not the trans.
The release arm is upright with the forks behind the flange on the TO bearing
The arm is held in place by a piece of tape (no kidding)
The trans is assembled onto the engine
The cross shaft is now installed to hold the arm in place
The tape is removed.
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 07-24-2014, 08:08 AM
i use a zip tie to hold the arm in place. bend a curve into the end and thread it into and out of the pressure plate spring slots behind the arm. easy to snip it and remove it after the trans is installed.
206 637 4071
Old 07-24-2014, 08:15 AM
bcheney's Avatar
G50 Installation
Well I feel stupid for not referencing my Bentley Manual before doing the install... I see exactly what you guys are talking about. Thanks...Kind like the zip tie idea over the tape though.
08 Cayenne V6
75 914-6 Conversion
Old 07-24-2014, 02:05 PM
JOHN THE ZIP TIE IS BRILLIANT THANKS I HAVE DONE THIS 3 TIMES AND EACH TIME HAVE FORGOTTEN ABOUT THE TAPING OF THE ARM UNBELIEVABLE Age catching up best frank
Old 08-13-2014, 05:03 PM
