-   -   )7 Targa Hatch Problem (http://forums.pelicanparts.com/porsche-911-technical-forum/822250-7-targa-hatch-problem.html)
que711 07-24-2014 05:24 PM
07 Targa rear hatch won't open. It unlatches and if you push on it from the inside it opens about 1" and then hit a secondary stop and will not open further. If you let go of it the close cycle activates and pulls it down tight. Anybody?
Jdub 07-24-2014 08:09 PM
You may not get a quick answer on this one - mostly earlier cars are discussed here. BUT, I am sure someone will step forward. Best of luck.
que711 07-25-2014 05:22 AM
Thanks for the reply. Is there a better place to get an answer? I think the struts may be bad, but don't see how to replace them if the hatch won't open. Thanks
Jack Stands 07-25-2014 05:47 AM
Try asking on the 996/997 forum, they might be more attuned to the later 911s.
Good luck!
que711 07-25-2014 05:53 AM
I've been driving a Porsche for over 30 years and have never used one of these forums. Thanks for the info.
Jack Stands 07-25-2014 06:02 AM
You'll find them invaluable, the amount of knowledge that's being shared is amazing ( and some is even correct :D).
