| Registered Join Date: Dec 2008 Location: Gladwyne, PA
				Interior trim question
			Hello I was trying to source the exact screws and washers that hold the rear parcel shelf, and other misc interior trim pieces. They are black and the head of the screw fits into the washer. Thanks.
|  07-28-2014, 10:09 AM |
| Registered Join Date: Dec 2012 Location: Seattle
			I think this set should cover it. I cant remember if the parcel shelf hardware was any bigger than the rest since it might be the heaviest interior piece. http://928classics.com/restoration-hardware.html
				__________________ 1982 911 Targa, 3.0L ROW with Webers | ||
|  07-28-2014, 10:22 AM |
| Fleabit peanut monkey |
			Hi Neal, From previous posts looks like you sold your SC and then were looking to buy a 993. What car are you working on? Don't know if it matters but may help.
				__________________ 1981 911SC Targa | ||
|  07-28-2014, 10:34 AM |
| Registered |
			Neal, am quite sure I get mine from Ace Hardware. Am probably going there tomorrow... will look and confirm.
				__________________ Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. Last edited by Discseven; 07-28-2014 at 11:47 AM.. | ||
|  07-28-2014, 11:42 AM |
			Bob- Its for a rear parcel shelf on a 993. I have another SC and I suppose I should just compare and contrast with that one and see if it is the same hardware. The kit that the other person posted above would be grest but I literally need 6 or so black interior trim screws and washers.. Thanks. | ||
|  07-28-2014, 11:43 AM |
| Registered Join Date: Jun 2013 Location: Park Ridge, IL
			I have a screw assortment similar to the 928classics kit.  It is extremely useful to have a screw just a little bit longer or bigger than the one you have removed.  The kit has saved me countless trips to the hardware store.  It is not a cheap convenience, but it is incredibly handy. Good luck, Dave | ||
|  07-28-2014, 12:01 PM |
			Dave, agreed. Now that I think of it, both door packets on my SC are not screwed onto the metal door any longer and the passenger side drags when using the door. I bet some of those are in the kit as well... Thanks. NealF '82 SC Targa '97 993 Coupe | ||
|  07-28-2014, 12:17 PM |
			I just did my door pockets in new carpet.  I found a hodge-podge of screws, including a drywall screw when I removed them.  I recommend pulling the pocket, then finding a screw that fits in each hole.  They may be different in size and length.  (Not from the factory, but from previous repairs.)  Then keep them in order and reinstall the pocket with relative ease.  This works on other panels too. Good luck, Dave | ||
|  07-28-2014, 01:13 PM |
| Fleabit peanut monkey | Quote:
 May not be a bad idea to snag this. SC door pocket screws look like the bottom row screw, one in from the left. If I remember they are more of a machine screw thread rather than a sheet metal screw thread.
|  07-28-2014, 01:20 PM |
