Power window passenger side
Could anyone please tell me the location for the relay on a 1986 911? Want to check that before I tear into the door panel removal. Thanks
Old 09-02-2015, 02:18 PM
universeman's Avatar
You can pull the door switch and test it without removing the door panel.
Jason - Austin, TX
82 911 SC targa (gone, but not forgotten)
92 968 coupe
Old 09-02-2015, 02:26 PM
Thanks. I actually switched out the drivers side switch that works and placed it on the passenger side, and still nothing
Old 09-02-2015, 03:38 PM
Do you have 12v power available? If so, jumper the wires coming out of the door and see if the motor kicks on / wdw moves.
Use this: Power Window Switch schematic
Jason - Austin, TX
92 968 coupe
Old 09-02-2015, 03:53 PM
Thanks for the info. I will try, but does anyone know where the relay is located for the window?? Thanks again
Old 09-03-2015, 05:39 AM
cycling has-been
bkreigsr's Avatar
Isn't there a schematic on the relay box in the frunk by the fuse panel? - at least a listing of what each of the individual relays are responsible for?
Bill K
Old 09-03-2015, 07:58 AM
Did you swap the drivers side passenger window control switch? Control goes from there to the other door.
Rick
88 Cab
Old 09-03-2015, 08:06 AM
Relay for window on my SC is the one I'm pointing at
Jason - Austin, TX
92 968 coupe
Old 09-03-2015, 10:33 AM
Smoove1010
Smoove1010's Avatar
The power window relay on my 87 is just ahead of the left side of the dashboard. See post #6 in this thread:
power window switch or relay help
1987 3.2 911 Cabriolet
Grand Prix White Exterior
Five Shades of Burgundy Interior
Old 09-04-2015, 04:05 PM
borrowed from another thread:
This is a good description of how that circuit works:
911 Power Window Troubleshooting [Archive] - Dorkiphus.net
Old 09-04-2015, 04:30 PM
Thanks to all for your replies. Being the eternal pessimist, just in case it's not the relay, can the window motor be repaired?? Thanks again for all of the replies, it's greatly appreciated
Old 09-05-2015, 08:03 AM
Yes, or replaced.
Jason - Austin, TX
92 968 coupe
Old 09-07-2015, 08:14 PM
