Kevin From Cali's Avatar
Help finding right size oil door
This is my 69 911 with I believe 72 flares from what I was told.
As you can see the existing door isn't the correct size, I found this one online, is it the correct one? If not does someone have one to sell me?
[IMG]Untitled[/IMG]
Porsche Oil Inlet Cover 911 504 415 01
Old 07-30-2014, 01:24 PM
Bill Verburg's Avatar
[IMG]Untitled[/IMG]
It may not be the door but rather the hole that's off
When I added SC flares to my '72 I bought SC quarter panels then cut the '72 door section out of the old quarters and grafted it into the new panel, I can easily envision someone doing it a little differently w/ the result you see.
Here's mine just before reassembly
Bill Verburg
Old 07-30-2014, 03:20 PM
They may have used a gas filler bucket rather than the rather rare '72 oil filler part. If your gas filler door looks like a good fit, another one is easy to find.
regards,
Phil
Old 07-30-2014, 08:07 PM
regards,
Phil
Good points, no gas filler on this, fuel cell is up front.
Old 07-30-2014, 10:31 PM
