-   -   Need ideas on hazard switch/flasher switch location (http://forums.pelicanparts.com/porsche-911-technical-forum/823571-need-ideas-hazard-switch-flasher-switch-location.html)
Dueller 08-02-2014 08:51 AM
In my minimalist interior project I'm deleting console, ac, radio. Néed to see some your ideas on switch placement.
Thanks in advace
Chuck.H 08-04-2014 10:59 AM
Hi Jim -
I removed my center console, and in the process kept the hazard and rear window defog switch together in their 'carrier', and bolted this under the glove compartment. I had to trim down the plastic piece to just around the switches. Been like this for over a year, I'm real happy with the modification.
Only slight drawback is I can't really see the switches, have to feel for them, and I don't always recall which is which. But I use them so infrequently it's not a problem.
In case you were wondering, the central locking thing I removed completely, and the two climate control switches sit in their carrier right in front of my shifter boot.
Chuck.H
'89 TurboLookTarga, 380k miles
JAR0023 08-04-2014 01:27 PM
Early cars it was over by the key, I think. You'd have to extend the wiring there. On my car I have a "blank" circle between the fog lamp switch and the lighter. Seems like you might could make the existing wiring work there. -J
Dueller 08-04-2014 04:32 PM
Thought about in radio delete plate but I like that plain panel. I have an opening to left off heater controls and one between cig lighter and fog lamps...could put them there.
mtb001 08-05-2014 08:24 PM
relocate defrost/hazard
I removed center console, have the blank between fog lights also, put hazard switch there, put defrost switch between heater controls and steering wheel.
Behind the vinyl next to the fog lights, there is already a cutout in the dash that would have fit the defrost switch nicely. Would have needed a much smaller hole as the switch comes apart for mounting. There is a post about mounting the switches, using hole saw and electrical knockout. The "easier" way to do this if not pulling the dash, is too pull fresh air blower/ducts. Comes out in less than 10 minutes and provides great access for wiring. I found small plastic a/c control mounting box, I think vintage a/c, and superglued under ashtray. Wires and capillary for a/c are both long enough.
Dueller 08-06-2014 04:41 AM
Thanks for the suggestions, guys. I remember the thread referred to but couldn't find it by searching. Perchance any body have a link? My dash is perfect and just don't want to damage upholstery when I go to drilling into it.
rs6er 08-06-2014 06:16 PM
I deleted my console and AC except for the fan. Then I made an L shape bracket with a curved R+L bottom edges out of aluminum (about 3" x 1.5" exposed), covered it with black upholstery fabric after drilling holes for the hazard switch and AC fan. I then attached the bracket to the bottom of the ash tray.
I'd post a picture, but my car is not here.
Dueller 08-06-2014 06:28 PM
Did mounting it there interfere with removing ashtray?
rs6er 08-06-2014 06:35 PM
No. It's mounted to the bottom of the ashtray. It doesn't replace it, though I did investigate that.
