Doug Zeilke, shim for CIS enrichment
Doug,
In reply to my post with questions of CIS, I told you wrong about the pressure regulator shims. I think I said "fuel inlet" to the mixture control. I just checked. On 924t, it is under a hex head screw, that is at a right to a big banjo fitting for fuel return & a small one to warm up regulator. More shim should increase the system presure & make mixture richer for flap movement.
Sorry, hope I caused no inconveinence.
drew1
Old 10-01-2002, 07:01 PM
