A pox on anyone who puts sealer on valve cover gaskets!
GRRRRR! That is all.
Fleabit peanut monkey
I do recall you have a special love for copious volumes of RTV.
1981 911SC Targa |
Carmagic.us
I agree, Sealer on the valve cover gaskets, and black undercoat on the car.......
Cheers Engelbert
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems |
When I picked up my '84 I noticed in the receipts that the previous owner had taken it to a Mercedes garage for a "re-seal" to address leaks. The valve covers had black RTV slathered all over them. For my first valve adjustment on the car I found them literally cemented on. I had a hell of time prying them off. I wanted to firebomb that shop (who should have known better).
Kurt |
Member 911 Anonymous
It just amazing. Nice vent JW.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
get the re-usable gaskets. they are WELL worth the money. very very light on the bolts when tightening. use a die on the studs to clean them up to get a better feel. if the gasket squeezes out its too tight.
(not advising JW, he knows).
The rubber ones are off-topic, but I have an issue with anything I can't tighten the nuts on. Bittch, bittch, bittch.
I think running the die over the studs is a great idea often missed .. the torque value on these is really low . it is entirely possible most of the torque is taken up by that nylock on the dirty messed up threads so the pressure holding the cover can be lower than you think or inconsistent.
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
Agree on the pox. Spent an hour or more just cleaning surfaces when I did my first valve adjust. People use sealant here to cover up poor workmanship. But I have gotten good at scraping sealing surfaces.
I've heard about some reusable air craft style valve cover seals. Has anyone ever used these? I don't recall who was offering them but I think they were silicone seals that could actually be reused many times.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
yeah as John points out that is another thread and they work. John was just venting what many of us have seen .. almost epoxied on covers . grrrr...
i went thru the same thing, had to clean all that crap off. even on the studs.
What I meant is with the rubber ones, the nuts can't be tightened all the way or the gasket pooches out. Just seems wrong to me. The rubber ones get returned in a ziplock no matter how awesome they are. Now if someone were to make HARD rubber gaskets....
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 10-07-2015 at 06:24 PM.. |
I have been looking at AMS Grades of Silicone Rubber and the hardest Grade is about 80 Shore A which may be OK but is about the same as the gaskets supplied on the lower cases of the 2.0litre engines and is much softer than the graphite style upper gaskets.
Ford make a Viton gasket for some of their UKL engines and they bond in a small sequence of steel bobbins as anti-crush devices but these wouldn't bond into silicone. I have recently seen gaskets with a silicone bead and will give them a go. |
We used to put some light valve grinding compound on a thickish sheet of plate glass and rub the covers (valve and other) around to get a truly flat surface.
Hey, it worked on small block chevys.
Bob F. 1984 Carrera Factory Turbo-Look |
Caveman Hammer Mechanic
I wouldn't use anything else.
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
