Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Clutch effort - 915 vs G50
At our local cars and coffee, I swapped my 86 that has the 915 transmission and a cable operated clutch with my buddies 88 that has the G50 and a hydraulic clutch. I hadn't experienced the new generation syncros. First thing we noticed was how much more effort his G50 clutch had. Not sure if his clutch is stock, mine is, also has a new cable. Is this higher effort for the G50 clutch normal? Thanks
Old 08-03-2014, 02:35 PM
I have driven several 915 cars and two G50 cars.
I have owned two 915 cars. The first a 79 SC had a very heavy clutch pedal and I assumed they were all like that. This was before I discovered Pelican. After selling it the buyer put in a new clutch and cable and reported a big improvement.
The second which I own now had a heavy clutch when I bought it , but a new omega spring, small arm and new cable makes for a very light pedal.
The first G50 was a test drive in the UK with a very heavy pedal the second here in OZ was a mates low milage 964 C4 had a very light pedal.
My point is that either if well maintained will have a light pedal.
My other impression between the two is the G50 had a shorter throw and seemed more accurate.
I have read in here that the vagueness in the 915 selection can be hugely improved with all new bushings. That is my next project!
Cheers
Bill
1977 Carrera 3.0
This much fun must be illegal!
Old 08-03-2014, 03:46 PM
Member 911 Anonymous
DRACO A5OG's Avatar
If you have a new Pressure Plate, it will feel much lighter. My old 915 Pressure Plate will feel much heavier than the G50 hydraulic.
'85 Carrera Targa
PCA/POC
Old 08-03-2014, 05:14 PM
Drisump's Avatar
I have a 915 and have driven a few others. Also I have driven a few G50's. The clutch is far more progressive in a G50 whereas the 915 seems to be engaged or not engaged with very little in between. In terms of effort I can't really say I've noticed a measurable difference. Cheers
Old 08-03-2014, 06:17 PM
If the G50 hasn't had the release shaft update (and even with it) the shaft can get a buildup of clutch dust that makes the effort very high. When cleaned and lubed, I find the G50 clutch effort 'medium' and silky smooth. But every 50k miles or so I find the fork/shaft needs to be cleaned up to keep it that way.
Chuck.H
'89 TurboLookTarga, 380k miles
Old 08-04-2014, 05:59 AM
Thanks to all for your helpful responses. Yes, I saw the update bulletin in the Bentley service manual so time to check the serial number. With that much difference in effort, something is not right and needs attending.
Old 08-04-2014, 09:11 AM
