How high can I safely rev?
I've been shifting in the 2K-3K range since I got the car. Normally when I'm cruising along I try not to rev the engine past 3K.
This past week I've been getting it up to 3.5K-4K before shifting and it feels great! I want to have fun but don't need a premature trip to the mechanic. Where do you guys shift? When cruising along in say 2nd what is the acceptable rev range before I should shift up or down?
1987 Carrera, Guards Red, Black (sold but never forgotten!)
1965 356SC Coupe, Silver on Red
Old 09-29-2002, 11:26 PM
GSpreeman,
You'll have to visit your mechanic sooner if you don't visit the upper end of your car's rev range at least five times during a 30-minute drive.
Ironic, eh?
Matt Holcomb
MFIWDP
PRVC
BOHICA
1974 911 Carrera 2.7 RoW
1975 Mercedes-Benz 280SE
Dedicated Homepage
Engine Rebuild Homepage
Porsche Owners Gallery Profile
Pelican Gallery Profile
Old 09-29-2002, 11:34 PM
eion's Avatar
Send a message via ICQ to eion Send a message via Yahoo to eion
I tend to shift near the redline, or at 5k revs at least. I don't downshift above 3.5k, usually at around 2.5k. The torque seems to really come on at 4k revs, so shifting before it gets there seems like a bit of a waste to me.
'90 C2 Coupe - 104k miles
Old 09-29-2002, 11:35 PM
Maybe I've been pampering it too much. I don't even know if I've seen 5K yet.
Old 09-29-2002, 11:39 PM
A Quiet Boom's Avatar
Think of it like this, figure out the rpm's a 911 would be turning on average at a decent speed on the autobahn, say 100 mph in top gear, then realize that this is done frequently for long periods of time. Next think of the overall build and design quaility of the 911 and what the intentions where, example how many street cars have dry sump oiling standard? These engines aren't really running below 3000 and the real fun starts at 4000, shifting at 3-4k is like having a thoroughbred and only taking him out for "pony rides". I shift mine below 5k only when noise might be an issue or if I'm just cruising along otherwise it's 5-6.5k quite often I'll redline 1st and 2nd then go straight to 4th or 5th depending on the limit and how fast I want to travel.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com
1966 912 converted to 3.0 and IROC body SOLD unfortunately
1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity!
Old 09-29-2002, 11:45 PM
avendlerdp's Avatar
Please tell me you are kidding. We are talking about Porsches here. These motors are designed to hit the redline with every shift, every day, year after year... It is a good thing to run the motor up to the higher RPM's every time you drive it. You bought it, use it.
Alex
Old 09-29-2002, 11:47 PM
CamB's Avatar
No maybe. Definitely too much pampering.
The best thing to do is make sure you engine is mechanically well in good shape, then drive it until it is nice and warm (180 deg plus).
THEN SPANK IT TO 6500!
Feels good
Very good
Seriously, as long as the engine is warm, any revs you like. A decent spanking will clean out the carbon, which may be the excuse you need to give to the policeman when he asks why you were going so fast...
(edit) By the way the early cars, especially the 'S', don't run all that well below 3000rpm.
1975 911S (in bits)
1969 911T (goes, but need fettling)
1973 BMW 2002tii (in bits, now with turbo)
Porsche spent a lot of money on engineers to design an engine that could safely be reved through it's power band. Unless your car has had an aftermarket chip put into the dme you can't reve it any higher than about 6500 rpms the computer stops you there. rev it all of the way until that point, you won't hurt anything. It's what they were designed for. This is not an American v8that lopes along at 1500rpms all day. You will actually harm the motor if you rev it too low. If you read the owner's manual for your '87 you'l see that they actually say the minimum rpms to shift to the next gear are around 2600 (all gears are slightly different)
REv it all the way up, you'll enjoy it, your car will enjoy it, and your car was designed for it.
Don't forget they put the peak of the torque curve at about 4800 and the peak of the hp curve at 5900, it would be poor design to do that if the car was best run at 3Krpm. Porsche doesn't design much that is pooorly designed.
Old 09-29-2002, 11:52 PM
It's 2:53 in the morning and I'm thinking about going out driving now!!!!! Feel like I've just been given a license to have fun!
Thanks everyone!
Old 09-29-2002, 11:55 PM
Re: How high can I safely rev?
Shift closer to 6000 RPM's and you will find god in the form of that flat 6 screaming like a monster.
Old 09-30-2002, 05:01 AM
Rick Lee's Avatar
All good advice here. But remember to take it easy until she's at operating temp. I think that's about 140 deg., or just outside the top of the lowest white mark in your oil temp gauge. Until it gets to that point, I shift between 3k-4k. Thereafter I don't shift under 5k and usually go to 6k.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 09-30-2002, 05:38 AM
I always shift near redline - thats why I bought a Porsche!
I cruise at 4000 rpm in any gear just so I can be ready to punch it when the time is right, plus it sounds really cool. Even on the highway at 75-85 mph I will still be in 4th.
Always wondered what 5th gear is for??? Redlining in 4th will send you to jail in most states.
Randy
'87 911 Targa
'17 Macan GTS
Old 09-30-2002, 05:41 AM
bigchillcar's Avatar
Shift when your ears pop...
Old 09-30-2002, 06:15 AM
Wink
G:
Take all this advise with a grain of salt. You dont want to be bringing your car up to the red-line every shift, every time you take her out.
Firstly, dont lug her. That would be too high a gear, too soon, so the motor bogs down.. Then you dont want to be crusing along in too high a gear and the motor turning too slow.
Shift-points like most things in life are variable. Use your ears. The load you are carrying plus the terrain and traffic patterns will determine shift points. While crusing in traffic - I would not let her fall much below 3200 RPM.
Then again, dont be afraid of the red-line. Porsches are built to rev. But beware - once you get into the higher RPMs, she is going to pull like a freight train. Things start to happen very quickly!
If you need some real world lessons, I live out in Brooklyn, I will be glad to show you..
B
Old 09-30-2002, 08:13 AM
Automotive Writer/DP
Randy W's Avatar
I would warm the car up by driving it for 5 miles while not lugging it and shifting at about 4K, then I would shift at 5K or higher. If you don't run it up to redline regularly, your valve guides will need replacing sooner, rather than later. 911s run better after the rev limiter is exercised occasionally. As for it wearing out sooner - everything wears out, even us! It's all about how much fun you have along the way.
1972 S - Early S Registry #187
1972 T/ST - R Gruppe #51
http://randywells.com
http://randywells.com/blog
Old 09-30-2002, 08:27 AM
Botman's Avatar
GSpreeman, here are 5 steps to being comfortable with your shift points.
1. Join the PCA
2. Save up $225.00
3. Sign up for the next DE in your local region
4. Drive your car for 2 days under instruction having the most fun that you have ever had (pants on or off).
5. Learn what your car is all about, and realize that it's comfort level is much higher than yours when it comes to RPMs.
You will truly be amazed at what your car (and you) are capable of.
Mike Patterson
Obsessive in Texas
86 3.2 Black on Black Carrera Coupe
73 BMW 2002 Verona Red
Old 09-30-2002, 08:32 AM
Hilbilly Deluxe
emcon5's Avatar
How will you know the rev limiter works if you don't bump your head on it from time to time?
Tom
82 911SC Coupe
GTI Cup #43
Old 09-30-2002, 09:00 AM
david914's Avatar
What's a Rev Limiter?
(the only Rev Limiter on my car is the one sitting in the driver's seat!)
Seriously, I try not to exceed around 3-3.5K RPM before the oil temp hits the 180 degree mark. After that it's playtime! Mine's touched the 7K mark many times without a glitch, but YMMV.
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 09-30-2002, 09:11 AM
Senior Member
Superman's Avatar
You're definitely making a mistake, GSpreeman. You're going to hurt your engine more by under-reving it than my over-reving it. The rev limiter will save you.
They say every Porsche ever built is a race car. That's true. Just like an Irish Setter likes to stretch its legs and get a little wind in its face, so too your Porsche likes to run. Find a helmet and get a tech inspection done, and take her to a track, for a treat. You want a real eye-opener, let the driving instructor take her for the first trip on the track, with you in the passenger seat.
I'm serious. Flog her good. She would love you for it. Spend ten minutes hard accelerating and hard decelerating, with rpms constantly in the 4000-6500 range. Make her scream. You'll both feel better. Afterwards, you'll notice she's happier. Whether she smokes a cigarette or not.
Mocha 1978 911SC. "Coco"
Old 09-30-2002, 10:38 AM
I did as the concensus said. Warmed her up and then started revving up to the 4-5K range. For the H*LL of it I just floored it to see how high it would rev and she goes all the way to the end of the tach. Of course I did this just as I noticed there was a cop parked at the red light. I'm sure he is dying to see my little pcar up close.
PS. Forget any questions I had about installing new stereo components. The 3.2 sounds just fine.
Old 09-30-2002, 10:50 AM
