Gentlemen, Thank you.
Anthony
1984 "Chiffon" Targa
1986 951 Wessiech
1986 951 Crystal Green Metallic
1986 951 Garnet Red
Old 08-07-2014, 06:24 AM
wolds's Avatar
You might want to remove, clean and reinstall your main ground strap while you're under the car. If you have a new one handy, better yet. Warren
Lorraine 83 SC CAB RoW
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 08-07-2014, 11:57 AM
RaketeRot
Draden's Avatar
Good point Warren. Such a small item and easy to forget, but a bad ground forces all your starter current to return path to the battery via the clutch cable. The result is it becomes brittle and breaks easy. Not to mention a weak ignition spark. -Draden
1967 911R hybrid clone
1973 911 RSR - coilovers, 2.8L twin plug RSR cam engine. butt welded metal RSR flares and metal frame ducktail
If it were easy, it would not require people of our caliber.
Old 08-07-2014, 12:49 PM
I will change it.
Thank you!
1986 951 Wessiech
1986 951 Garnet Red
Old 08-07-2014, 01:56 PM
