-   -   ducktail on C2 (http://forums.pelicanparts.com/porsche-911-technical-forum/82416-ducktail-c2.html)
axl911 09-30-2002 09:32 AM
ducktail on C2
Anyone here ever put a ducktail on a c2?
I like the duck tail on a 911.
If so, what's involved? What does the tail do /w the aiflow to the engine, if any?
Also, does the early 911 chrome headlight rings fit on the C2?
Anyone has a pic of how the chrome headlight rings and ducktail would look on a C2?
I am thinking of going to a retro look.
thanks,
anthony
atlporsche 09-30-2002 09:38 AM
a quick search turned up the following...
http://forums.pelicanparts.com/showthread.php?s=&threadid=81589&highlight=993+duc ktail
sjd
Mark Wilson 09-30-2002 10:20 AM
Anthony,
The Duck should be a bolt on for a C2. Just know that nearly all new fglass parts need some trimming/adjusting to fit. I've never seen one on a C2, but I bet it would look great. I have read posts that the duck aids engine cooling at, but have no hard evidence to back it. My SC does drive better since the install.
Where in TX are you?
Mark
http://forums.pelicanparts.com/uploads/nice fr.11.jpg
axl911 09-30-2002 10:50 AM
Mark,
I am located here in Dallas. Don't have a C2 yet, but looking to get one. I'd like to go retro on the C2.
When you said the ducktail should bolt on, you mean the "duck" part of the tail just bolt to the existing C2 deck lid? Or you meant a new complete tail (minus the spoiler). Pls elaborate further.
thanks,
anthony
Mark Wilson 09-30-2002 11:45 AM
The only ones I am aware of replace the entire decklid. You can buy a new glass unit for $3-400 and have if painted, bolt it on and voila, instant duck. You are welcome to come out and look at mine any time.
http://forums.pelicanparts.com/uploads/rq_0292.13.jpg
Vipergrün 09-30-2002 02:34 PM
Originally posted by axl911
Mark,
Hi Anthony, I know the actual tail/lid will fit your C2, but I do not know about the hinges. If I were to put a C2 decklid on my SC I'd have to hack/change the hinges. Just a thought.
cheers
-Brad
80SC
Mark Wilson 09-30-2002 03:45 PM
Sorry Anthony. I may have given bad info. The 964 lid with extendo wing does have a different hinge setup. You may have to do some fabrication.
Try posting the question on the 964 board....or get an SC!!!!! There's a very exclusive club, you know.
Jeff964 09-30-2002 06:19 PM
1 Attachment(s)
You mean like this
axl911 09-30-2002 09:51 PM
Yeah, kinda like the picture except without the big wheel, rubberband tire, and lowered til it scrapes the ground effect. That thing looks riced out. Not what I want. I like a more retro RS look.
Anyone know what kind of modification is needed for the hinges?
Also, anyone know where I can get the chrome headling trim ring?
thanks,
anthony
efhughes3 10-01-2002 06:01 AM
Hey Mark:
Your car is looking good. I like the pic from the front RH corner. Have you come to like your polished wheels yet, they look great.
yeuporsch 10-01-2002 03:33 PM
ducktail
It would be an interesting looking, definitely retro. Has anyone put a ducktail on a C2 with turbo rear end? I have a 72T with a C2 Turbo look and was thinking changing the turbo tea tray tail for the duck look. Anyone done this?
John
bento 10-01-2002 03:57 PM
by the way, i know that grey car. it was the feature project car of EGO magazine which is one of the two japanese porsche rags. they basically ripped out the carpet, put carbon fiber door panels on it, lowered it on H&R springs, put new wheels on it, painted to match duct tape (i kid you not, it's what they used for the color), and did the duct tail.
so you were right, it is ricey. but at least it's tastefully done.
db
Roland Kunz 10-02-2002 09:55 AM
Hello
To mount a pre 89 decklid onto a 964 you have to modify the hinges or make intermetiate plates.
Oo Fibergals ducktails from the aftermarked you mostly have to manufacture a bracket for the hinge anyhow so just bolt it on to the 964 hinges.
Grüsse
Fritz 10-02-2002 04:00 PM
Made to order ducktails
If you want to spend some real money, I understand there is a guy/company in Florida who molds the fiberglass decklid, just the outer skin and then bonds it to the existing decklids metal frame.
I would assume you could simply provide a C2 lid for him to get the frame from and let him bond the ducktail skin to it. That way the hinges are correct.
I also believe this is how the original RS ducktails were built, a fiberglass skin bonded onto the metal frame of a regular decklid. But I'm not an expert by any means so maybe someone could help out on this.
I will have to dig deep for his info. Let me know if you want me to.
Roland Kunz 10-03-2002 01:00 PM
Hello
Now the original ducktails had a aluminium or steelframe inside, good copys also use a steelframe ( mostly cut from a orignial lid ).
But most copys out there are full fibre with just molded in aluminium or steel plates on the "critical" positions.
Grüsse
jriera 10-03-2002 01:09 PM
The company name is Made by Hand, they are in Tallahase, FL. Not cheap but they look great look at this --> http://www.mbhinc.com/html/duck_tails.html.
Regards
