Question on Proper application of gasket goop on exhaust
When I installed my heat exchangers, I used high-temp gasket goop. I applied to both sides of the gasket and let sit for 10 minutes before installing.
I later had an issue and had to remove one of the heat exchangers (before starting engine), and I was surprised how easy it was to remove the gaskets. Now I'm wondering if I applied the goop incorrectly. Should I be adding this to the gasket or the manifold/heat exchangers. I'm trying to insure that I have absolutely no leaks.
Any advice would be appreciated. This is something I can easily fix now before my first startup.
Thanks!
Old 10-14-2014, 12:40 PM
lespaul's Avatar
Subscribed. Will be facing this challenge momentarily.
Brad
Inventor of SNAPGAP - The Valve Adjustment Solution
Patented in U.S. and Europe. Go to SNAPGAP.US or PM me.
https://www.pelicanparts.com/More_Info/SNPVAK11146.htm?pn=SNP-VAK11146
Old 10-14-2014, 01:33 PM
pete3799's Avatar
Just put SSI's on this spring. Dry gaskets, no leaks.
Pete
79 911SC RoW
Old 10-14-2014, 05:40 PM
use the 84-89 carrera gaskets with no sealer. not needed.
206 637 4071
Old 10-14-2014, 05:44 PM
I'm not sure I agree. The Carrera gaskets are for 42mm ports I.D. My 2.7 has 38mm ports.
Old 10-14-2014, 11:56 PM
Slippery Slope Expert
Steam Driver's Avatar
Sealer really not required or called for in this application.
Old 10-15-2014, 04:19 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Appropriate gasket, no sealer.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 10-15-2014, 11:13 AM
Got it! No sealer.
Old 10-15-2014, 11:15 AM
This application calls for some long-life preservative/coating for threads and threaded fasteners. Not sure whether Never-Seez, Dow 111 or other is the best for long term corrosion protection. If you ever tried to remove decades old heat exchangers, you know what I mean.
Comments?
Sherwood
Old 10-15-2014, 11:35 AM
Comments?
Sherwood
Sherwood, if you only knew... Ok, here's what happened, I just pulled the engine for my PMO project and spent an entire month attempting to get the exhaust off. Of course part of that month was replacing the 5 broken studs and installing timeserts.
So, now that I'm putting it all back together.....I want it right and I don't want any leaks!
Old 10-15-2014, 01:58 PM
I have been fighting with an exhaust leak on my 69 - pinhole leak that causes backfire on decel. as near as I can figure, I have one exhaust port flange that isn't "true" so I may need to try some good (as much as it irks me to have to do it).
Keith - Calgary
1969 912R (911 engine) - Blutorange
Old 10-15-2014, 08:16 PM
