Removing undercoating stuff?
My SC has some kind of black undercoating material around the tops of the shock towers, in the trunk. Looks like it was applied at the factory - although I can't figure out why they did that (I've also seen the same on some 914s - some had it, some didn't).
Anyways, any suggestions on the best way to remove it? |
I think that stuff helps waterproof your trunk. Undercoating is removed with a plastic scraper and a heat gun.
Super is correct. However that stuff gets brittle when it gets old. You might find that using the plastic scraper and a light touch from a hammer that the stuff will just chip off in good size pieces.
For the stubborn tar remains ... Varsol or 3M Paint Cleaner on a terry cloth.
| All times are GMT -8. The time now is 10:47 PM. |
