Removing undercoating stuff?
My SC has some kind of black undercoating material around the tops of the shock towers, in the trunk. Looks like it was applied at the factory - although I can't figure out why they did that (I've also seen the same on some 914s - some had it, some didn't).
Anyways, any suggestions on the best way to remove it?
Old 09-30-2002, 01:29 PM
Senior Member
Superman's Avatar
I think that stuff helps waterproof your trunk. Undercoating is removed with a plastic scraper and a heat gun.
Mocha 1978 911SC. "Coco"
Old 09-30-2002, 02:03 PM
Friend of Warren
Super is correct. However that stuff gets brittle when it gets old. You might find that using the plastic scraper and a light touch from a hammer that the stuff will just chip off in good size pieces.
Kurt V
Old 09-30-2002, 02:20 PM
Early_S_Man's Avatar
For the stubborn tar remains ... Varsol or 3M Paint Cleaner on a terry cloth.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 09-30-2002, 02:24 PM
