Smuggler's box question
What is the ribbed plastic tube for and where does that big round hole in the bottom of the smuggler's box go?
"Charlie don't surf!" |
The ribbed tube is the drain for any water that enters via the fresh air inlet vent just at the rear of the hood. The opening is the A/C evaporator inflow duct from the driver's footwell area.
We need a place to have a real tech night for all of us in this area that isn't set up by the Vancouver ( sorry) Porsche club where us novices can ask people those questions we would rather ask between friends
Lorne M.
83 SC |
Air Medal or two
talk to gaunter
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
Ubi bene ibi patria
By:LM3929
Cheers JB Hey vancouver86/911 - my apologies for what looks to be a thread hi-jack of sorts.
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke "As soon as laws are necessary for men, they are no longer fit for freedom." - Pythagoras Last edited by Hawkeye's-911T; 10-16-2014 at 02:26 PM.. |
U'r/We're from the wrong side of the pond!!
Mill Beatty Coordinator for the 911 Carrera 3.0 North American registry site> |
That is a vestige of the Webasto heater which connects there and pulls air in from the center tunnel. Air enters through a grille that covers the shift coupler, flows up the tunnel and goes into the webasto, where it flows across a stainless steel heat exchanger, gets very hot and then flows out to the defroster and heat tubes.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
I plugged mine with a cap from a plumbing supply store. Painted it black and dropped it in. Fit perfectly. Let me know if you want pic of what I did.
1982 911 Targa, 3.0L ROW with Webers |
This is what my smuggler's box looks like in my non a/c 86 Carrera. Is it likely that this hole was covered up by someone? That holes looks like it lines up perfectly with the opening at the bottom of the evaporator blower assembly I have.
If it's a non A/C car and that's the only hole in the floor, than the hose in your picture (fresh air drain) should fit down through it.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
The hole in the floor of the smuggler's box I was referring to is the huge one that is evident in the top picture of someone's car but not in the bottom picture of my smuggler's box.
+1 for an appropriate, accurate use of the word "vestige." Refreshing. (Pun intended.)
Remember our friends: Warren, Ron, Grady, and Steve. 76 912E RS (i.e. "Real Slow"); 63 Volvo P1800 "S"; 71 Jaguar XJ6 Series 1; 05 GT3; 23 Cayman GTS 4.0; 97 Boxster |
Factory shipped non-A/C equipped, holes/ducts not there.
Does this hole need to be cut out to retro fit the stock a/c system?
