Cars and Cappuccino
tdw28210's Avatar
M491 Wheel Question
I should know this already, but I want to be sure. And I am away from my M491 so I cannot verify myself.
Question: I believe most of the earlier The M491's came from the factory with 7J and 8J wheels, (sporting a 944.xxx.xxx.xx part number) and factory wheel spacers.
In the later years, they came from the factory with actual turbo wheels (7's and 9's) with a 911.362.XXX part numbers. Yes/No? Thanks.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 08-26-2014, 04:57 AM
Bill Verburg's Avatar
Early M491('84-85) cars came w/ 911 7ET23.3 & 8ET10.6 x18 and 28mm spacers only in the rear, from '86 the rears were 9ET15 x16 w/ the same spacer
There were no street M491 that were regular production cars prior to '84
The 930s from '75-80 used the same 911 7ET23.3 wheels but w/ a 21mm spacer, the hub design changed in '80 so the front spacer wasn't needed any more, the first few years on 930 also used 7ET23.3 ans 8ET10.5 x15 the first year 16s were offered was '77. These were all 9111 wheels as well.
Bill Verburg
Old 08-26-2014, 06:04 AM
Slippery Slope Victim
NY65912's Avatar
Yes. My '85 M491 has 7's & 8's. They went to 7 & 9's in 1986.
MikeČ
1985 M491
Old 08-26-2014, 06:11 AM
Shaun @ Tru6's Avatar
My 84 has 7x8x16 and had no problem putting on 225/245 RE11s. Great tire, good size for the car.
Tru6 Restoration & Design
Old 08-26-2014, 06:39 AM
Cars and Cappuccino
tdw28210's Avatar
Thanks. Hmmm....so maybe it's the wheel spacers have a 944 part number then?
Old 08-26-2014, 07:12 AM
Dave Colangelo's Avatar
The Fuchs were an option on the 944 if memory serves and may have been standard on the 944 Turbos I cant remember. Im not sure why they would have switched the part numbers to a 944 part number but they are a legitimate 944 part as well as a 911 part.
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 08-26-2014, 07:49 AM
The M491 were never specced with 944 part number (951 wheels) fuchs.
Old 08-26-2014, 08:19 AM
gearhead
Dave
They have a 944 part number because their offset is different than those used on 911s.
Old 08-26-2014, 08:22 AM
Matt, there's more to that than just offset. The 944 part number 7X16 has the same offset as the 911 version, but a different face, allowing room for the brake calipers. It looks like a 6, but with countersunk lug holes.
The 8 has indeed a different offset, 23.3 vs 10.8mm
Old 08-26-2014, 08:27 AM
RSM-M491's Avatar
TDW, you getting some new shoes for your ride?
1989 911 Targa M491
1980 Triumph TR8 (sold)
2006 BMW M3 (Interlagos Blue)
Old 08-26-2014, 08:44 AM
There may be a 944 wheel spacer but an M491 should have the following spacers
21mm 930.341.611.00 front
28mm 930.331.611.04 rear
back in the '70s there was supposed to be a 54mm, 930.331.911.04
but I haven't seen one. Doesn't mean they don't exist either as I have rarely been up close and personal w/ 930s
There was also 477.501.701 which is also a 21mm spacer and was I have seen these all over the place
Bill Verburg
Old 08-26-2014, 08:48 AM
944 Fuchs came in 2 flavors
7ET23.3 x16 and 8ET23.3 x16
both have BB clearance
Bill Verburg
Old 08-26-2014, 08:50 AM
Cars and Cappuccino
tdw28210's Avatar
Maybe. .
Old 08-26-2014, 09:15 AM
Cars and Cappuccino
tdw28210's Avatar
Thanks again Bill. So is it possible that given that the 944 Fuchs have turbo brake clearance, that my M491 came from the factory with Weissach edition 944 Fuchs rather than 911 versions?
Old 08-26-2014, 10:50 AM
The odds are long, nothing is impossible though. The 930 brakes fit in 15s just fine.
Bill Verburg
Old 08-26-2014, 11:03 AM
It has nothing to do with clearance on stock cars.
*Any* fuchs 15" and larger fits over std Carrera or 930 brakes that are original fitment.
When one fits 930 brakes to a 911 suspension, then special measures are needed in front, which is where the 944 numbered Fuchs enter the scene.
But on a factory specced car, turbo look or not, any fuchs 15 and larger fits.
Old 08-26-2014, 11:50 AM
Not really George,
The front of the early 930 thru '77 had the same brakes as the n/a 911S, which used 6ET36 x15 wheels, the 930 used 7ET23.3 x15 which are the same 911 wheels that were used in the back of the 2.7RS, to fill out the fenders Porsche added a 21mm spacer, this spacer was used right up until the front hub redesign in '80, the hub redesign made the spacer integral to the hub so no more separate spacer but the wheels were positioned the same as previously, the 21mm spacer was also used when the big brakes were incorporated in '78. The wheel width and ET7ET23.3 was the same for 15 and 16" fitments, again standard 911 wheels are all that's needed.
In back the 930 has wider trailing arms that move the 8ET10.6 wheels out some, but they still needed spacers back there, the same spacer was continued for 15 and 16 and for 8 and 9 wheels. In '76 the Carrera 3.0 and the 930 used the exact same 7 & 8 x15 wheel sets and 205/50 & 225/50 x15 tires, std on the 930, options on the Carrera 3.0
Bill Verburg
Old 08-26-2014, 12:37 PM
Cars and Cappuccino
tdw28210's Avatar
Not really George,
Seriously Bill, GREAT info. Thanks. But, how the HE!! do you know all of this stuff? I am beginning to think you a re a Google bot or something. : D
Old 08-26-2014, 04:58 PM
Not really George,
Which is what I wrote/meant. Any stock 930 takes any 15'' and larger wheel.there is no need for the 951 specific rims on any 911/930 as they were delivered by the factory.
Old 08-26-2014, 09:45 PM
Cars and Cappuccino
tdw28210's Avatar
Thanks for the clarification George. It is appreciated.
Old 08-27-2014, 08:13 AM
