High oil pressure at idle
I've installed my 3.0L engine and started it for the first time in 2 years. Seems oil pressure is running high at idle. When first started its at 4 bar. After a couple minutes it lowers to about 2.5 to 3. If I give it a little gas it rises as normal. I don't think it ran at high pressure before I put the engine in storage but I could be wrong - 2 years is a long time. I did replace the oil pressure sender just as preventive maintenance. I believe I purchased the correct sender (VDO 911-606-111-03-M82 0-5 bars). Before I start the car with the key on the gauge is at 0 and if I pull the wire off it pegs to 5. Running 20w50 dino-oil.
Should I run the engine more after being in storage and drained of oil for so long? Should I install new pressure relief valves? Or something else to check? Or am I overacting to cold pressure?
DD summer/winter: 2000 Boxster S
DD spring/fall: 914-6 w/ 3.0L SC Dual Webers (For Sale)
http://imgur.com/a/k0Wtl - My 914-6 Build/Project Story
Old 08-27-2014, 07:41 PM
ROW '78 911 Targa
timmy2's Avatar
Sounds about the same as mine when cold with 20-50 in it.
When the engine is fully warmed up it will drop down to about 1 bar at idle.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 08-27-2014, 10:01 PM
kodioneill's Avatar
Normal
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 08-29-2014, 05:42 AM
