-   -   Basic questions 930: Intercooler upgrade, engine insulation (http://forums.pelicanparts.com/porsche-911-technical-forum/827267-basic-questions-930-intercooler-upgrade-engine-insulation.html)
Hippie 930 08-28-2014 06:12 AM
I have a couple of questions:
1) If I upgrade my OEM intercooler to an Andial long neck,do I need to remove the OEM air filter box? Would the Andial fit with the air box in? I see lots of air intake modifications when these oil coolers are upgraded, but want to make sure before I buy this IC.
2) Engine compartment insulation- I removed the heating system and heat exchangers for headers. Work perfect. Still, now I have some holes in the engine bay that remain after these ducts were removed, leaving some areas for heat convection from headers/ exhaust performance muffler and K27 turbo to potentially ascend(hit air always goes up!) into the engine bay/ intercooler/ a/c interaction.
Car runs very nicely in FL summer heat(90's) weather at 190°, raises to 200-210° in traffic jams but I have a front oil cooler, so never higher than that. My car is black,and want to stay away from those orange/ red or related silicone materials. Prefer black or related.
I am thinking on "sealing" those gaps/ holes with foam, rubber or related (fire retardant of course), any suggestions and where to get these?
Thanks, Carl
Uwon 08-29-2014 03:31 AM
Hey Carl,
You should probably re-post your questions in the 930 forum for better responses. Lots of very knowledgeable turbo nuts there.
Cheers,
Johan
Hippie 930 08-29-2014 04:50 AM
Already did, thanks.
